Ana içeriğe geç
Hover-1 H1 Battery Replacement
Neye ihtiyacın var
  1. Hover-1 H1 Battery Replacement, Bottom Shell: adım 1, 1 resimden 1.
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Battery Replacement: adım 2, 1 resimden 1.
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Battery Replacement: adım 3, 2 resimden 1. Hover-1 H1 Battery Replacement: adım 3, 2 resimden 2.
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Battery Replacement: adım 4, 1 resimden 1.
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  6. Hover-1 H1 Battery Replacement: adım 6, 1 resimden 1.
    • Gently lift the battery harness and remove the battery by lifting the battery and moving it away from the hoverboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Aaron Teh
442 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 üyesi
CPSU-WHITE-F18S17G6
4 Üyeler
7 adet Kılavuz yazıldı
11 Yorum
The stickers were the trick. I didn’t see them!
Daniel D - Yanıt
After removing the 4 screws that is holding the battery in place I still can't remove the battery. I tried gently to pry under the battery but it doesn't budge. Uni Sun model HY-A01B. How do I solve this problem?
Terry Pollard - Yanıt
Where do I get another battery to replace it???
Tony Pate - Yanıt
That's the question I can't seem to find the answer to
Darin -
Very low quality. Bought for my son who haven’t even used it for 15 times. Got it during winter and before summer the product stopped working.
tosin3in1 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 41
Son 30 gün: 190
Her zaman: 8,869
