Ana içeriğe geç
Hover-1 H1 Charging Port Replacement
Neye ihtiyacın var
  1. Hover-1 H1 Charging Port Replacement, Bottom Shell: adım 1, 1 resimden 1.
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Charging Port Replacement: adım 2, 1 resimden 1.
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Charging Port Replacement: adım 3, 2 resimden 1. Hover-1 H1 Charging Port Replacement: adım 3, 2 resimden 2.
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Charging Port Replacement: adım 4, 1 resimden 1.
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Charging Port Replacement, Charging Port: adım 5, 2 resimden 1. Hover-1 H1 Charging Port Replacement, Charging Port: adım 5, 2 resimden 2.
    • Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
    • Be careful to not damage the wires or connector when removing the glue.
  6. Hover-1 H1 Charging Port Replacement: adım 6, 1 resimden 1.
    • Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
  7. Hover-1 H1 Charging Port Replacement: adım 7, 2 resimden 1. Hover-1 H1 Charging Port Replacement: adım 7, 2 resimden 2.
    • Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
    • It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
  8. Hover-1 H1 Charging Port Replacement: adım 8, 2 resimden 1. Hover-1 H1 Charging Port Replacement: adım 8, 2 resimden 2.
    • Pull the charging port to the left through the shell.
Sonuç
Madeline David
280 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 üyesi
CPSU-WHITE-F18S17G6
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
I need to replace the charging port on my H1 hoverboard. Can you share the link for the actual replacement part.
prdrngga - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 47
Her zaman: 3,852
