Ana içeriğe geç
Hover-1 H1 Gyroscope Sensor Assemblies Replacement
Neye ihtiyacın var
  1. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Bottom Shell: adım 1, 1 resimden 1.
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 2, 1 resimden 1.
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 3, 2 resimden 1. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 3, 2 resimden 2.
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 4, 1 resimden 1.
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: adım 5, 2 resimden 1. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: adım 5, 2 resimden 2.
    • On the battery side of the hoverboard, remove the red, black, and purple sleeved cable from the sensor assembly by squeezing the tab and pulling up.
  6. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 6, 2 resimden 1. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 6, 2 resimden 2.
    • Remove the red, blue, and green cable from the cable extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  7. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 7, 2 resimden 1. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 7, 2 resimden 2.
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  8. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 8, 1 resimden 1.
    • Remove the sensor assembly on the battery side of the hoverboard by gently lifting and pulling away from the hoverboard.
  9. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 9, 3 resimden 1. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 9, 3 resimden 2. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 9, 3 resimden 3.
    • Remove the hot glue holding in the connectors with a utility knife.
    • Remove the white cable from the sensor assembly by squeezing the connector and pulling the connector up.
    • Be careful not to touch any parts of the circuit boards with the knife.
  10. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 10, 1 resimden 1.
    • Remove the red, blue, and green cable from the extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  11. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 11, 2 resimden 1. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 11, 2 resimden 2.
    • Remove the red and black sleeved connector from the sensor assembly by squeezing the tab and pulling up.
  12. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 12, 2 resimden 1. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 12, 2 resimden 2.
  13. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: adım 13, 1 resimden 1.
    • Remove the sensor assembly on the motherboard side of the hoverboard by gently lifting and pulling away from the hoverboard.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Aaron Teh
442 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 üyesi
CPSU-WHITE-F18S17G6
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
where can I get the replacement parts?
Rob Sayles - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 35
Son 30 gün: 115
Her zaman: 4,879
