Ana içeriğe geç
Hover-1 H1 LED Headlight Replacement
Neye ihtiyacın var
  1. Hover-1 H1 LED Headlight Replacement, Bottom Shell: adım 1, 1 resimden 1.
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  2. Hover-1 H1 LED Headlight Replacement: adım 2, 1 resimden 1.
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  3. Hover-1 H1 LED Headlight Replacement: adım 3, 2 resimden 1. Hover-1 H1 LED Headlight Replacement: adım 3, 2 resimden 2.
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
    FixBot'a Sor
    Yorum Ekle
  4. Hover-1 H1 LED Headlight Replacement: adım 4, 1 resimden 1.
    • Unplug the battery by pulling gently on both sides of the orange connector.
    FixBot'a Sor
    Yorum Ekle
  5. Hover-1 H1 LED Headlight Replacement, LED Headlights: adım 5, 1 resimden 1.
    • Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
    FixBot'a Sor
    Yorum Ekle
  6. Hover-1 H1 LED Headlight Replacement: adım 6, 1 resimden 1.
    • Remove the vertical light from the shell by using your hands to pull it free from the surrounding shell.
    FixBot'a Sor
    Yorum Ekle
  7. Hover-1 H1 LED Headlight Replacement: adım 7, 1 resimden 1.
    • Remove two 8mm screws using a Phillips #0 screwdriver to rotate the screws counterclockwise.
    • Remove the horizontal light by using your fingers to pull the light up out of the shell.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sara Passantino
347 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 üyesi
CPSU-WHITE-F18S17G6
4 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 39
Her zaman: 1,687
