Ana içeriğe geç
Hover-1 H1 Power Button Replacement
Neye ihtiyacın var
  1. Hover-1 H1 Power Button  Replacement, Bottom Shell: adım 1, 1 resimden 1.
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  2. Hover-1 H1 Power Button  Replacement: adım 2, 1 resimden 1.
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  3. Hover-1 H1 Power Button  Replacement: adım 3, 2 resimden 1. Hover-1 H1 Power Button  Replacement: adım 3, 2 resimden 2.
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
    FixBot'a Sor
    Yorum Ekle
  4. Hover-1 H1 Power Button  Replacement: adım 4, 1 resimden 1.
    • Unplug the battery by pulling gently on both sides of the orange connector.
    FixBot'a Sor
    Yorum Ekle
  5. Hover-1 H1 Power Button  Replacement, Power Button: adım 5, 1 resimden 1.
    • Unplug the power button connector by pinching the tab on the front and pulling directly upwards.
    • Pull the cable through the center section of the hoverboard.
    • For reassembly, you will have to feed the cable back through the center section. This can be done using a rigid wire or cable.
    FixBot'a Sor
    Yorum Ekle
  6. Hover-1 H1 Power Button  Replacement: adım 6, 2 resimden 1. Hover-1 H1 Power Button  Replacement: adım 6, 2 resimden 2.
    • Using an adjustable wrench, remove the nut on the back of the power button by rotating the nut counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  7. Hover-1 H1 Power Button  Replacement: adım 7, 1 resimden 1.
    • Pull the power button through the hole in the shell.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekip
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 üyesi
CPSU-WHITE-F18S17G6
4 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 51
Her zaman: 4,038
