Ana içeriğe geç
Hover-1 H1 Shell Replacement
Neye ihtiyacın var
  1. Hover-1 H1 Shell Replacement, Bottom Shell: adım 1, 1 resimden 1.
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Shell Replacement: adım 2, 1 resimden 1.
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Shell Replacement: adım 3, 2 resimden 1. Hover-1 H1 Shell Replacement: adım 3, 2 resimden 2.
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Shell Replacement: adım 4, 1 resimden 1.
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Shell Replacement, LED Headlights: adım 5, 1 resimden 1.
    • Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
  6. Hover-1 H1 Shell Replacement: adım 6, 1 resimden 1.
    • Remove the vertical light from the shell by using your hands to pull it free from the surrounding shell.
  7. Hover-1 H1 Shell Replacement: adım 7, 1 resimden 1.
    • Remove two 8mm screws using a Phillips #0 screwdriver to rotate the screws counterclockwise.
    • Remove the horizontal light by using your fingers to pull the light up out of the shell.
  8. Hover-1 H1 Shell Replacement, Charging Port: adım 8, 2 resimden 1. Hover-1 H1 Shell Replacement, Charging Port: adım 8, 2 resimden 2.
    • Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
    • Be careful to not damage the wires or connector when removing the glue.
  9. Hover-1 H1 Shell Replacement: adım 9, 1 resimden 1.
    • Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
  10. Hover-1 H1 Shell Replacement: adım 10, 2 resimden 1. Hover-1 H1 Shell Replacement: adım 10, 2 resimden 2.
    • Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
    • It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
  11. Hover-1 H1 Shell Replacement: adım 11, 2 resimden 1. Hover-1 H1 Shell Replacement: adım 11, 2 resimden 2.
    • Pull the charging port to the left through the shell.
  12. Hover-1 H1 Shell Replacement, Power Button: adım 12, 1 resimden 1.
    • Unplug the power button connector by pinching the tab on the front and pulling directly upwards.
    • Pull the cable through the center section of the hoverboard.
    • For reassembly, you will have to feed the cable back through the center section. This can be done using a rigid wire or cable.
  13. Hover-1 H1 Shell Replacement: adım 13, 2 resimden 1. Hover-1 H1 Shell Replacement: adım 13, 2 resimden 2.
    • Using an adjustable wrench, remove the nut on the back of the power button by rotating the nut counterclockwise.
  14. Hover-1 H1 Shell Replacement: adım 14, 1 resimden 1.
    • Pull the power button through the hole in the shell.
  15. Hover-1 H1 Shell Replacement, Shell: adım 15, 3 resimden 1. Hover-1 H1 Shell Replacement, Shell: adım 15, 3 resimden 2. Hover-1 H1 Shell Replacement, Shell: adım 15, 3 resimden 3.
    • Remove the sixteen 10mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
    • Remove the two 12mm Phillips #2 machine screws by using a screwdriver to rotate the screws counterclockwise.
  16. Hover-1 H1 Shell Replacement: adım 16, 1 resimden 1.
    • Lift both the left and right sides of the top half of the shell from the hoverboard's chassis.
  17. Hover-1 H1 Shell Replacement: adım 17, 1 resimden 1.
    • Remove the two 8mm Phillips #0 screws on the right half of the shell by using a screwdriver to rotate the screws counterclockwise.
    • Repeat for the left side of the shell.
  18. Hover-1 H1 Shell Replacement: adım 18, 1 resimden 1.
    • Lift the shell to remove it from the chassis.
Sonuç
Sara Passantino
326 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 üyesi
CPSU-WHITE-F18S17G6
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 19
Her zaman: 1,192
