Ana içeriğe geç
Hover-1 Horizon Left Balancing Sensor Replacement
Neye ihtiyacın var
  1. Hover-1 Horizon Left Balancing Sensor Replacement, Base Plate: adım 1, 2 resimden 1. Hover-1 Horizon Left Balancing Sensor Replacement, Base Plate: adım 1, 2 resimden 2.
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Hover-1 Horizon Left Balancing Sensor Replacement: adım 2, 2 resimden 1. Hover-1 Horizon Left Balancing Sensor Replacement: adım 2, 2 resimden 2.
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Hover-1 Horizon Left Balancing Sensor Replacement: adım 3, 3 resimden 1. Hover-1 Horizon Left Balancing Sensor Replacement: adım 3, 3 resimden 2. Hover-1 Horizon Left Balancing Sensor Replacement: adım 3, 3 resimden 3.
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: adım 4, 3 resimden 1. Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: adım 4, 3 resimden 2. Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: adım 4, 3 resimden 3.
    • Remove the two connectors on either side of the board by lifting the tab and pulling out.
    • Remove the connector in the middle of the board by squeezing the tab and pulling up.
  5. Hover-1 Horizon Left Balancing Sensor Replacement: adım 5, 2 resimden 1. Hover-1 Horizon Left Balancing Sensor Replacement: adım 5, 2 resimden 2.
    • Remove the four 11mm Phillips #1 screws that hold the cover on.
  6. Hover-1 Horizon Left Balancing Sensor Replacement: adım 6, 3 resimden 1. Hover-1 Horizon Left Balancing Sensor Replacement: adım 6, 3 resimden 2. Hover-1 Horizon Left Balancing Sensor Replacement: adım 6, 3 resimden 3.
    • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
    • Lift the board to reveal the connections on the bottom.
  7. Hover-1 Horizon Left Balancing Sensor Replacement: adım 7, 2 resimden 1. Hover-1 Horizon Left Balancing Sensor Replacement: adım 7, 2 resimden 2.
    • Remove the middle connector by squeezing the top of the tab and pulling up.
  8. Hover-1 Horizon Left Balancing Sensor Replacement: adım 8, 3 resimden 1. Hover-1 Horizon Left Balancing Sensor Replacement: adım 8, 3 resimden 2. Hover-1 Horizon Left Balancing Sensor Replacement: adım 8, 3 resimden 3.
    • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
    • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
  9. Hover-1 Horizon Left Balancing Sensor Replacement: adım 9, 3 resimden 1. Hover-1 Horizon Left Balancing Sensor Replacement: adım 9, 3 resimden 2. Hover-1 Horizon Left Balancing Sensor Replacement: adım 9, 3 resimden 3.
    • Unclip the black connector by squeezing both sides and pulling them apart.
  10. Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: adım 10, 3 resimden 1. Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: adım 10, 3 resimden 2. Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: adım 10, 3 resimden 3.
    • Remove the three 10 mm Phillips #1 screws connecting the balance sensor to the hoverboard.
    • The balance sensor tabs are made of sensitive rubber. Screw them back on slowly, and do not over-tighten.
  11. Hover-1 Horizon Left Balancing Sensor Replacement: adım 11, 2 resimden 1. Hover-1 Horizon Left Balancing Sensor Replacement: adım 11, 2 resimden 2.
    • Remove the sensor tab by carefully lifting it away from the hoverboard.
Sonuç
Jesus
85 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G6, White Fall 2018 Cal Poly, Team S13-G6, White Fall 2018 üyesi
CPSU-WHITE-F18S13G6
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 859
