Ana içeriğe geç
Hover-1 Horizon Power Button Replacement
Neye ihtiyacın var
  1. Hover-1 Horizon Power Button Replacement, Base Plate: adım 1, 2 resimden 1. Hover-1 Horizon Power Button Replacement, Base Plate: adım 1, 2 resimden 2.
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Hover-1 Horizon Power Button Replacement: adım 2, 2 resimden 1. Hover-1 Horizon Power Button Replacement: adım 2, 2 resimden 2.
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Hover-1 Horizon Power Button Replacement: adım 3, 3 resimden 1. Hover-1 Horizon Power Button Replacement: adım 3, 3 resimden 2. Hover-1 Horizon Power Button Replacement: adım 3, 3 resimden 3.
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Hover-1 Horizon Power Button Replacement, Power Button: adım 4, 1 resimden 1.
    • Reorient the Hover-1 Horizon so the base plate opens towards you.
  5. Hover-1 Horizon Power Button Replacement: adım 5, 3 resimden 1. Hover-1 Horizon Power Button Replacement: adım 5, 3 resimden 2. Hover-1 Horizon Power Button Replacement: adım 5, 3 resimden 3.
    • Remove the connector by squeezing the tab and lifting up.
  6. Hover-1 Horizon Power Button Replacement: adım 6, 3 resimden 1. Hover-1 Horizon Power Button Replacement: adım 6, 3 resimden 2. Hover-1 Horizon Power Button Replacement: adım 6, 3 resimden 3.
    • Remove the second connector by squeezing the tab and pulling up.
  7. Hover-1 Horizon Power Button Replacement: adım 7, 3 resimden 1. Hover-1 Horizon Power Button Replacement: adım 7, 3 resimden 2. Hover-1 Horizon Power Button Replacement: adım 7, 3 resimden 3.
    • Unscrew the power button by holding the front and twisting the back nut counter-clockwise.
    • Push the power button through the base plate to remove.
    • A hot air gun may need to be used to remove the adhesive connecting the base plate to the power button.
Sonuç
Christina Fong
165 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G6, White Fall 2018 Cal Poly, Team S13-G6, White Fall 2018 üyesi
CPSU-WHITE-F18S13G6
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 53
Her zaman: 805
