Ana içeriğe geç
Hover-1 Horizon Wheel Wires Replacement
Neye ihtiyacın var
    1. Hover-1 Horizon Wheel Wires Replacement, Base Plate: adım 1, 2 resimden 1. Hover-1 Horizon Wheel Wires Replacement, Base Plate: adım 1, 2 resimden 2.
      • Remove the six 12mm Phillips #2 screws holding the base plate.
      FixBot'a Sor
      Yorum Ekle
    2. Hover-1 Horizon Wheel Wires Replacement: adım 2, 2 resimden 1. Hover-1 Horizon Wheel Wires Replacement: adım 2, 2 resimden 2.
      • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
      FixBot'a Sor
      Yorum Ekle
    3. Hover-1 Horizon Wheel Wires Replacement: adım 3, 3 resimden 1. Hover-1 Horizon Wheel Wires Replacement: adım 3, 3 resimden 2. Hover-1 Horizon Wheel Wires Replacement: adım 3, 3 resimden 3.
      • Remove the base plate by lifting it up.
      • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
      FixBot'a Sor
      Yorum Ekle
    1. Hover-1 Horizon Wheel Wires Replacement, Left Gyroscope Sensor Board: adım 4, 3 resimden 1. Hover-1 Horizon Wheel Wires Replacement, Left Gyroscope Sensor Board: adım 4, 3 resimden 2. Hover-1 Horizon Wheel Wires Replacement, Left Gyroscope Sensor Board: adım 4, 3 resimden 3.
      • Remove the two connectors on either side of the board by lifting the tab and pulling out.
      • Remove the connector in the middle of the board by squeezing the tab and pulling up.
      FixBot'a Sor
      Yorum Ekle
    2. Hover-1 Horizon Wheel Wires Replacement: adım 5, 2 resimden 1. Hover-1 Horizon Wheel Wires Replacement: adım 5, 2 resimden 2.
      • Remove the four 11mm Phillips #1 screws that hold the cover on.
      FixBot'a Sor
      Yorum Ekle
    3. Hover-1 Horizon Wheel Wires Replacement: adım 6, 3 resimden 1. Hover-1 Horizon Wheel Wires Replacement: adım 6, 3 resimden 2. Hover-1 Horizon Wheel Wires Replacement: adım 6, 3 resimden 3.
      • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
      • Lift the board to reveal the connections on the bottom.
      FixBot'a Sor
      Yorum Ekle
    4. Hover-1 Horizon Wheel Wires Replacement: adım 7, 2 resimden 1. Hover-1 Horizon Wheel Wires Replacement: adım 7, 2 resimden 2.
      • Remove the middle connector by squeezing the top of the tab and pulling up.
      FixBot'a Sor
      Yorum Ekle
    5. Hover-1 Horizon Wheel Wires Replacement: adım 8, 3 resimden 1. Hover-1 Horizon Wheel Wires Replacement: adım 8, 3 resimden 2. Hover-1 Horizon Wheel Wires Replacement: adım 8, 3 resimden 3.
      • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
      • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
      FixBot'a Sor
      Yorum Ekle
    6. Hover-1 Horizon Wheel Wires Replacement: adım 9, 3 resimden 1. Hover-1 Horizon Wheel Wires Replacement: adım 9, 3 resimden 2. Hover-1 Horizon Wheel Wires Replacement: adım 9, 3 resimden 3.
      • Unclip the black connector by squeezing both sides and pulling them apart.
      FixBot'a Sor
      Yorum Ekle
    1. Hover-1 Horizon Wheel Wires Replacement, Wheel Wires: adım 10, 2 resimden 1. Hover-1 Horizon Wheel Wires Replacement, Wheel Wires: adım 10, 2 resimden 2.
      • Remove the four 30mm Hex #6 screws.
      FixBot'a Sor
      Yorum Ekle
    2. Hover-1 Horizon Wheel Wires Replacement: adım 11, 3 resimden 1. Hover-1 Horizon Wheel Wires Replacement: adım 11, 3 resimden 2. Hover-1 Horizon Wheel Wires Replacement: adım 11, 3 resimden 3.
      • Remove the metal square by lifting it up and setting it to the side.
      FixBot'a Sor
      Yorum Ekle
    3. Hover-1 Horizon Wheel Wires Replacement: adım 12, 1 resimden 1.
      • Check that all the clips are secured properly.
      FixBot'a Sor
      Yorum Ekle
    4. Hover-1 Horizon Wheel Wires Replacement: adım 13, 3 resimden 1. Hover-1 Horizon Wheel Wires Replacement: adım 13, 3 resimden 2. Hover-1 Horizon Wheel Wires Replacement: adım 13, 3 resimden 3.
      • Remove the clip by squeezing the latch that holds the clips together while pulling apart.
      • Check motion of the wheel after the clip is disconnected. If the wheel is still stuck, reconnect the clip and disconnect the next one.
      • Remove the clip by squeezing the tab while pulling the clip apart.
      FixBot'a Sor
      Yorum Ekle
    5. Hover-1 Horizon Wheel Wires Replacement: adım 14, 3 resimden 1. Hover-1 Horizon Wheel Wires Replacement: adım 14, 3 resimden 2. Hover-1 Horizon Wheel Wires Replacement: adım 14, 3 resimden 3.
      • Disconnect the remaining three clips by pulling them apart.
      • After each clip is disconnected, check to see if the motion of the wheel has improved. If the wheel is still stuck, reconnect the clip and unclip the next one.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jenny Dyer
235 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G6, White Fall 2018 Cal Poly, Team S13-G6, White Fall 2018 üyesi
CPSU-WHITE-F18S13G6
4 Üyeler
48 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 1,532
