Ana içeriğe geç
Hover-1 Horizon Wheel/Motor Replacement
Neye ihtiyacın var
    1. Hover-1 Horizon Wheel/Motor Replacement, Base Plate: adım 1, 2 resimden 1. Hover-1 Horizon Wheel/Motor Replacement, Base Plate: adım 1, 2 resimden 2.
      • Remove the six 12mm Phillips #2 screws holding the base plate.
      FixBot'a Sor
      Yorum Ekle
    2. Hover-1 Horizon Wheel/Motor Replacement: adım 2, 2 resimden 1. Hover-1 Horizon Wheel/Motor Replacement: adım 2, 2 resimden 2.
      • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
      FixBot'a Sor
      Yorum Ekle
    3. Hover-1 Horizon Wheel/Motor Replacement: adım 3, 3 resimden 1. Hover-1 Horizon Wheel/Motor Replacement: adım 3, 3 resimden 2. Hover-1 Horizon Wheel/Motor Replacement: adım 3, 3 resimden 3.
      • Remove the base plate by lifting it up.
      • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
      FixBot'a Sor
      Yorum Ekle
    1. Hover-1 Horizon Wheel/Motor Replacement, Left Gyroscope Sensor Board: adım 4, 3 resimden 1. Hover-1 Horizon Wheel/Motor Replacement, Left Gyroscope Sensor Board: adım 4, 3 resimden 2. Hover-1 Horizon Wheel/Motor Replacement, Left Gyroscope Sensor Board: adım 4, 3 resimden 3.
      • Remove the two connectors on either side of the board by lifting the tab and pulling out.
      • Remove the connector in the middle of the board by squeezing the tab and pulling up.
      FixBot'a Sor
      Yorum Ekle
    2. Hover-1 Horizon Wheel/Motor Replacement: adım 5, 2 resimden 1. Hover-1 Horizon Wheel/Motor Replacement: adım 5, 2 resimden 2.
      • Remove the four 11mm Phillips #1 screws that hold the cover on.
      FixBot'a Sor
      Yorum Ekle
    3. Hover-1 Horizon Wheel/Motor Replacement: adım 6, 3 resimden 1. Hover-1 Horizon Wheel/Motor Replacement: adım 6, 3 resimden 2. Hover-1 Horizon Wheel/Motor Replacement: adım 6, 3 resimden 3.
      • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
      • Lift the board to reveal the connections on the bottom.
      FixBot'a Sor
      Yorum Ekle
    4. Hover-1 Horizon Wheel/Motor Replacement: adım 7, 2 resimden 1. Hover-1 Horizon Wheel/Motor Replacement: adım 7, 2 resimden 2.
      • Remove the middle connector by squeezing the top of the tab and pulling up.
      FixBot'a Sor
      Yorum Ekle
    5. Hover-1 Horizon Wheel/Motor Replacement: adım 8, 3 resimden 1. Hover-1 Horizon Wheel/Motor Replacement: adım 8, 3 resimden 2. Hover-1 Horizon Wheel/Motor Replacement: adım 8, 3 resimden 3.
      • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
      • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
      FixBot'a Sor
      Yorum Ekle
    6. Hover-1 Horizon Wheel/Motor Replacement: adım 9, 3 resimden 1. Hover-1 Horizon Wheel/Motor Replacement: adım 9, 3 resimden 2. Hover-1 Horizon Wheel/Motor Replacement: adım 9, 3 resimden 3.
      • Unclip the black connector by squeezing both sides and pulling them apart.
      FixBot'a Sor
      Yorum Ekle
    1. Hover-1 Horizon Wheel/Motor Replacement, Wheel/Motor: adım 10, 3 resimden 1. Hover-1 Horizon Wheel/Motor Replacement, Wheel/Motor: adım 10, 3 resimden 2. Hover-1 Horizon Wheel/Motor Replacement, Wheel/Motor: adım 10, 3 resimden 3.
      • Remove the four 30mm Hex #6 screws.
      • Lift away the silver bracket and set it to the side.
      FixBot'a Sor
      Yorum Ekle
    2. Hover-1 Horizon Wheel/Motor Replacement: adım 11, 3 resimden 1. Hover-1 Horizon Wheel/Motor Replacement: adım 11, 3 resimden 2. Hover-1 Horizon Wheel/Motor Replacement: adım 11, 3 resimden 3.
      • Disconnect the first clip by squeezing the latch that hold the clips together while pulling apart.
      • Disconnect the second clip by squeezing the tab while pulling the clip apart.
      FixBot'a Sor
      Yorum Ekle
    3. Hover-1 Horizon Wheel/Motor Replacement: adım 12, 3 resimden 1. Hover-1 Horizon Wheel/Motor Replacement: adım 12, 3 resimden 2. Hover-1 Horizon Wheel/Motor Replacement: adım 12, 3 resimden 3.
      • Detach the remaining three connections by pulling them apart.
      FixBot'a Sor
      Yorum Ekle
    4. Hover-1 Horizon Wheel/Motor Replacement: adım 13, 2 resimden 1. Hover-1 Horizon Wheel/Motor Replacement: adım 13, 2 resimden 2.
      • Remove the wheel by lifting it away from the base with both hands.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Casey Winans
324 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G6, White Fall 2018 Cal Poly, Team S13-G6, White Fall 2018 üyesi
CPSU-WHITE-F18S13G6
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 1,086
