Ana içeriğe geç
Hover-1 Liberty Battery Replacement
Neye ihtiyacın var
  1. Hover-1 Liberty Battery Replacement, Bottom Cover: adım 1, 2 resimden 1. Hover-1 Liberty Battery Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  2. Hover-1 Liberty Battery Replacement: adım 2, 2 resimden 1. Hover-1 Liberty Battery Replacement: adım 2, 2 resimden 2.
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
    FixBot'a Sor
    Yorum Ekle
  3. Hover-1 Liberty Battery Replacement: adım 3, 3 resimden 1. Hover-1 Liberty Battery Replacement: adım 3, 3 resimden 2. Hover-1 Liberty Battery Replacement: adım 3, 3 resimden 3.
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  4. Hover-1 Liberty Battery Replacement, Battery: adım 4, 2 resimden 1. Hover-1 Liberty Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Disconnect the large red and black wire from the battery by pulling apart the connector.
    FixBot'a Sor
    Yorum Ekle
  5. Hover-1 Liberty Battery Replacement: adım 5, 2 resimden 1. Hover-1 Liberty Battery Replacement: adım 5, 2 resimden 2.
    • Remove the four 15mm Phillips #1 screws from the bracket holding the battery in place.
    FixBot'a Sor
    Yorum Ekle
  6. Hover-1 Liberty Battery Replacement: adım 6, 2 resimden 1. Hover-1 Liberty Battery Replacement: adım 6, 2 resimden 2.
    • Remove the bracket by pulling it upwards, away from the hoverboard.
    • You will need to move some wires aside to remove the bracket successfully.
    FixBot'a Sor
    Yorum Ekle
  7. Hover-1 Liberty Battery Replacement: adım 7, 3 resimden 1. Hover-1 Liberty Battery Replacement: adım 7, 3 resimden 2. Hover-1 Liberty Battery Replacement: adım 7, 3 resimden 3.
    • Remove the battery by grasping the battery and hoverboard firmly and pulling apart.
    • The battery is held in place by adhesive. So, some force is required to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Patrick Bacon
438 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G2, White Fall 2018 Cal Poly, Team S13-G2, White Fall 2018 üyesi
CPSU-WHITE-F18S13G2
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 60
Her zaman: 3,264
