Ana içeriğe geç
Hover-1 Liberty Bottom Cover Replacement
Neye ihtiyacın var
  1. Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: adım 1, 2 resimden 1. Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  2. Hover-1 Liberty Bottom Cover Replacement: adım 2, 2 resimden 1. Hover-1 Liberty Bottom Cover Replacement: adım 2, 2 resimden 2.
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
    FixBot'a Sor
    Yorum Ekle
  3. Hover-1 Liberty Bottom Cover Replacement: adım 3, 3 resimden 1. Hover-1 Liberty Bottom Cover Replacement: adım 3, 3 resimden 2. Hover-1 Liberty Bottom Cover Replacement: adım 3, 3 resimden 3.
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Patrick Bacon
438 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G2, White Fall 2018 Cal Poly, Team S13-G2, White Fall 2018 üyesi
CPSU-WHITE-F18S13G2
3 Üyeler
4 adet Kılavuz yazıldı
2Kılavuz Yorumları
I'm gettin nothin at all.. Charger is green.. But absolutely nothing when press the on button.. All the cables are connected.. No lights or anythin.. Can anyone help.
stemirnoff@hotmail.co.uk - Yanıt Paylaş
I am getting the 5 red lights. I have followed all the instructions. Is there a site to buy the motherboards that are burned out? Is it financially worth buy both boards and replacing them?
-Christopher Fields, Network Engineer, PC Repair, Grantsville, UT
Christopher Fields - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 52
Her zaman: 3,660
