Ana içeriğe geç
Hover-1 Liberty Bottom Cover Replacement
Neye ihtiyacın var
  1. Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: adım 1, 2 resimden 1. Hover-1 Liberty Bottom Cover Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Bottom Cover Replacement: adım 2, 2 resimden 1. Hover-1 Liberty Bottom Cover Replacement: adım 2, 2 resimden 2.
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Bottom Cover Replacement: adım 3, 3 resimden 1. Hover-1 Liberty Bottom Cover Replacement: adım 3, 3 resimden 2. Hover-1 Liberty Bottom Cover Replacement: adım 3, 3 resimden 3.
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Patrick Bacon
411 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G2, White Fall 2018 Cal Poly, Team S13-G2, White Fall 2018 üyesi
CPSU-WHITE-F18S13G2
3 Üyeler
4 adet Kılavuz yazıldı
2 Yorum
I'm gettin nothin at all.. Charger is green.. But absolutely nothing when press the on button.. All the cables are connected.. No lights or anythin.. Can anyone help.
stemirnoff@hotmail.co.uk - Yanıt
I am getting the 5 red lights. I have followed all the instructions. Is there a site to buy the motherboards that are burned out? Is it financially worth buy both boards and replacing them?
-Christopher Fields, Network Engineer, PC Repair, Grantsville, UT
Christopher Fields - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 2,941
