Ana içeriğe geç
Hover-1 Liberty Gyroscope Sensor Boards Replacement
Neye ihtiyacın var
  1. Hover-1 Liberty Gyroscope Sensor Boards Replacement, Bottom Cover: adım 1, 2 resimden 1. Hover-1 Liberty Gyroscope Sensor Boards Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Flip the hoverboard over so the labels are facing upwards.
    • Remove the twenty 18mm screws using a Phillips #2 screwdriver and twisting counterclockwise.
  2. Hover-1 Liberty Gyroscope Sensor Boards Replacement: adım 2, 2 resimden 1. Hover-1 Liberty Gyroscope Sensor Boards Replacement: adım 2, 2 resimden 2.
    • Remove the bottom cover by lifting it away from the hoverboard.
    • The cover on the side without the battery has two wires connecting the power button and charging port.
  3. Hover-1 Liberty Gyroscope Sensor Boards Replacement: adım 3, 3 resimden 1. Hover-1 Liberty Gyroscope Sensor Boards Replacement: adım 3, 3 resimden 2. Hover-1 Liberty Gyroscope Sensor Boards Replacement: adım 3, 3 resimden 3.
    • Remove one connector from the non-battery side circuit board.
    • Remove the next connector from the non-battery side circuit board.
    • To remove the connectors, pinch the plug and pull away from the circuit board.
  4. Hover-1 Liberty Gyroscope Sensor Boards Replacement, Gyroscope Sensor Boards: adım 4, 1 resimden 1.
    • Place the hoverboard so the sensor boards face you.
  5. Hover-1 Liberty Gyroscope Sensor Boards Replacement: adım 5, 2 resimden 1. Hover-1 Liberty Gyroscope Sensor Boards Replacement: adım 5, 2 resimden 2.
    • Remove battery connector by pulling it apart.
    • Slide the rubber sheaths away from the connector on the blue, green, and yellow wires.
    • Disconnect the colored wires by pulling them apart.
    • The large colored wires connecting the sensor boards to the wheels need to match for the motor to operate correctly.
  6. Hover-1 Liberty Gyroscope Sensor Boards Replacement: adım 6, 2 resimden 1. Hover-1 Liberty Gyroscope Sensor Boards Replacement: adım 6, 2 resimden 2.
    • Remove the white cable from the sensor boards by disconnecting the cable on each side of the hoverboard.
    • To release the cable connector, squeeze the sides while pulling it away from the sensor board.
  7. Hover-1 Liberty Gyroscope Sensor Boards Replacement: adım 7, 2 resimden 1. Hover-1 Liberty Gyroscope Sensor Boards Replacement: adım 7, 2 resimden 2.
    • Remove the four 10mm screws with a Phillips #1 screwdriver.
  8. Hover-1 Liberty Gyroscope Sensor Boards Replacement: adım 8, 2 resimden 1. Hover-1 Liberty Gyroscope Sensor Boards Replacement: adım 8, 2 resimden 2.
    • Remove the sensor board by lifting it away from the hoverboard.
    • Repeat steps 4-8 to remove the sensor board from the other side.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Eduardo Miranda
355 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G2, White Fall 2018 Cal Poly, Team S13-G2, White Fall 2018 üyesi
CPSU-WHITE-F18S13G2
3 Üyeler
4 adet Kılavuz yazıldı
9Kılavuz Yorumları
Where can you purchase the replacement board for the Hover-1 liberty?
Clifton Hale - Yanıt
Where do you get replacement board?
Tim Sole - Yanıt
After riding just a few times the hover board wouldn’t move. Also it has a rattle inside
Regina - Yanıt
Make this site useful by telling us where we can buy a new circuit board.
tim stoinski - Yanıt
Where do you get circuit board from.
markrichardowen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 9,769
