Ana içeriğe geç
Hover-1 Matrix Battery Replacement
Neye ihtiyacın var
  1. Hover-1 Matrix Battery Replacement, Battery: adım 1, 3 resimden 1. Hover-1 Matrix Battery Replacement, Battery: adım 1, 3 resimden 2. Hover-1 Matrix Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the twenty screws from the top outer cover using a Phillips #1 screwdriver.
    • Lift the left and right sides of the outer cover away from the rest of the hoverboard.
  2. Hover-1 Matrix Battery Replacement: adım 2, 3 resimden 1. Hover-1 Matrix Battery Replacement: adım 2, 3 resimden 2. Hover-1 Matrix Battery Replacement: adım 2, 3 resimden 3.
    • Remove the screws from the battery cover using a Philiips #1 screwdriver.
  3. Hover-1 Matrix Battery Replacement: adım 3, 3 resimden 1. Hover-1 Matrix Battery Replacement: adım 3, 3 resimden 2. Hover-1 Matrix Battery Replacement: adım 3, 3 resimden 3.
    • Move the plastic cover from the top of the battery.
    • Unplug the cables that connect to the battery and remove the battery from the hoverboard.
Sonuç
To reassemble the device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Ziru Mo
121 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S7-G2, Lore Fall 2018 UC Davis, Team S7-G2, Lore Fall 2018 üyesi
UCD-LORE-F18S7G2
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 851
