Ana içeriğe geç
Hover-1 Maverick Motor Wheel Replacement
Neye ihtiyacın var
  1. Hover-1 Maverick Motor Wheel Replacement, Motherboard: adım 1, 3 resimden 1. Hover-1 Maverick Motor Wheel Replacement, Motherboard: adım 1, 3 resimden 2. Hover-1 Maverick Motor Wheel Replacement, Motherboard: adım 1, 3 resimden 3.
    • *Using a 15mm Phillips screwdriver remove the 20 #1 screws from the shell of the hoverboard.
    • Open the shell.
    • There is one motherboard on each side of the device located near the wheels.
    FixBot'a Sor
    • Turn off hoverboard.
    FixBot'a Sor
  2. Hover-1 Maverick Motor Wheel Replacement: adım 3, 2 resimden 1. Hover-1 Maverick Motor Wheel Replacement: adım 3, 2 resimden 2.
    • Disconnect the battery to prevent any electrical currents from coming through the wires.
    FixBot'a Sor
  3. Hover-1 Maverick Motor Wheel Replacement: adım 4, 2 resimden 1. Hover-1 Maverick Motor Wheel Replacement: adım 4, 2 resimden 2.
    • Squeeze and pull on the wires to detach them from the motherboard.
    FixBot'a Sor
  4. Hover-1 Maverick Motor Wheel Replacement: adım 5, 2 resimden 1. Hover-1 Maverick Motor Wheel Replacement: adım 5, 2 resimden 2.
    • Remove the four 8mm Phillips #1 screws.
    • Remove the motherboard from the device.
    • Repeat for the other motherboard.
    FixBot'a Sor
  5. Hover-1 Maverick Motor Wheel Replacement, Motor: adım 6, 2 resimden 1. Hover-1 Maverick Motor Wheel Replacement, Motor: adım 6, 2 resimden 2.
    • After the motherboard is removed from either side, remove the four 15 mm hex screws with a 5mm Allen wrench.
    • Remove the metal covering from over the motor.
    FixBot'a Sor
  6. Hover-1 Maverick Motor Wheel Replacement: adım 7, 1 resimden 1.
    • The motor is attached to the wheel, so in order to remove the motor, you must take out the entire wheel.
    FixBot'a Sor
Sonuç
Piper Feldman
409 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G2, White Winter 2020 Cal Poly, Team S2-G2, White Winter 2020 üyesi
CPSU-WHITE-W20S2G2
2 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 71
Her zaman: 777
