Giriş
If the LED headlights on your Nomad do not light up when the hoverboard is powered on, your headlights may be damaged. Follow this guide to replace the headlights in the Hover-1 Nomad.
Neye ihtiyacın var
Break the two warranty stickers by poking a screwdriver through them or peeling them off.
Remove the following twenty screws by rotating the screwdriver counterclockwise:
Eight 16.2mm Phillips #2 screws
Eight 15mm Phillips #2 screws
Four 19.1mm Phillips #2 screws
Remove the two 13mm Phillips #1 screws by rotating the screwdriver counterclockwise.
Bir başkası bu kılavuzu tamamladı.
