Ana içeriğe geç
Hover-1 Rally Acceleration Lever Replacement
Neye ihtiyacın var
  1. Hover-1 Rally Acceleration Lever Replacement, Acceleration Lever: adım 1, 1 resimden 1.
    • Remove one 4 mm Phillips #1 screw located directly above the acceleration lever.
  2. Hover-1 Rally Acceleration Lever Replacement: adım 2, 2 resimden 1. Hover-1 Rally Acceleration Lever Replacement: adım 2, 2 resimden 2.
    • Turn the right handle grip counterclockwise.
    • The right handle will disconnect from the handlebar, exposing the acceleration lever.
  3. Hover-1 Rally Acceleration Lever Replacement: adım 3, 1 resimden 1.
    • Remove four 2 mm Phillips #00 screws located on the acceleration throttle.
  4. Hover-1 Rally Acceleration Lever Replacement: adım 4, 1 resimden 1.
    • Pull the acceleration lever off of the handle.
    • The acceleration lever sits perpendicular to the handle.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Van Schneider
112 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G2, Regan Winter 2020 Cal Poly, Team S7-G2, Regan Winter 2020 üyesi
CPSU-REGAN-W20S7G2
6 Üyeler
7 adet Kılavuz yazıldı
4 Yorum
Where did you find the lever?
Jaimi Erwin - Yanıt
See comment below. Swap out your power throttle with the brake lever. Or reach out to Hover-1 for spare parts.
Chris Serio -
Thank you Mr Fix It Man. I haven't used my scooter in months and never tried to find parts. Swapped my throttle out with my brake lever and we're good to go hehe
Chris Serio - Yanıt
The throttle lever on my daughter’s scooter broke off and I have been unable to get through to Hover for replacement parts (both online and tried to call). Do you know of any universal levers that would work? Or where I could locate a lever? Bought this for my daughter to get to college classes and this is her first week and it broke (out of 90 day warranty, of course.)
Sharon Kolson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 53
Her zaman: 2,115
