Ana içeriğe geç
Hover-1 Rally Brake Pad Replacement
Neye ihtiyacın var
    1. Hover-1 Rally Brake Pad Replacement, Rear Wheel: adım 1, 1 resimden 1.
      • Remove the 4 mm screw in center of the wheel with a 4 mm hex key.
      • Flip the scooter and remove the same size screw from the opposite side of the wheel.
      FixBot'a Sor
      Yorum Ekle
    2. Hover-1 Rally Brake Pad Replacement: adım 2, 1 resimden 1.
      • Slide the plastic side piece off from both sides of the scooter.
      • Two 4 mm screws and 2 side panels are taken out.
      FixBot'a Sor
      Yorum Ekle
    3. Hover-1 Rally Brake Pad Replacement: adım 3, 2 resimden 1. Hover-1 Rally Brake Pad Replacement: adım 3, 2 resimden 2.
      • Use a 4 mm bit extension to push the axle out of the wheel’s center.
      FixBot'a Sor
      Yorum Ekle
    4. Hover-1 Rally Brake Pad Replacement: adım 4, 1 resimden 1.
      • Grab the deck of the scooter, and pull the wheel downwards.
      • 2 washers will fall out with the wheel.
      FixBot'a Sor
      Yorum Ekle
    1. Hover-1 Rally Brake Pad Replacement, Brake Pad: adım 5, 1 resimden 1.
      • Begin by removing the two 8.0 mm screws from the deck using the Phillips #2 screwdriver.
      • Two screw caps will come off with the screws
      FixBot'a Sor
      Yorum Ekle
    2. Hover-1 Rally Brake Pad Replacement: adım 6, 1 resimden 1.
      • Pull the foot brake/ wheel cover away from the deck and downwards.
      FixBot'a Sor
      Yorum Ekle
    3. Hover-1 Rally Brake Pad Replacement: adım 7, 1 resimden 1.
      • On the foot brake, remove the two 8.0 mm screws using the Phillips #2 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Hover-1 Rally Brake Pad Replacement: adım 8, 1 resimden 1.
      • On the opposite side of the brake, remove the silver brake pad.
      • If this is your first time replacing this part, the removal might require more force. You may need to use the flat end of a spudger to pry it off.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Elizabeth Picazo
207 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G2, Regan Winter 2020 Cal Poly, Team S7-G2, Regan Winter 2020 üyesi
CPSU-REGAN-W20S7G2
6 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 34
Her zaman: 1,050
