Giriş
If your Hover-1 Rally (model H1-RALY) scooter squeaks or fails to stop when you apply the brake, use this guide to replace the foot brake. The brake pad should be checked first when brakes are ineffective.
Foot brake replacement is common and necessary after long-term use. Avoid riding in dust and other debris to increase the lifespan of your brake pads.
Make sure to power off the scooter before you replace the brake pad.
Neye ihtiyacın var
Remove the 4 mm screw in center of the wheel with a 4 mm hex key.
Flip the scooter and remove the same size screw from the opposite side of the wheel.
Begin by removing the two 8.0 mm screws from the deck using the Phillips #2 screwdriver.
2 farklı kişi bu kılavuzu tamamladı.
