Ana içeriğe geç
Hover-1 Rally Rear Wheel Replacement
Neye ihtiyacın var
  1. Hover-1 Rally Rear Wheel Replacement, Rear Wheel: adım 1, 1 resimden 1.
    • Remove the 4 mm screw in center of the wheel with a 4 mm hex key.
    • Flip the scooter and remove the same size screw from the opposite side of the wheel.
    The bit for the screwdriver is a hex/allen bit, not a Phillips.
    Dylan Ruiz - Yanıt
    You don’t need to specify which direction to turn the screwdriver to remove the screw.
    Jason Pagendarm - Yanıt
  2. Hover-1 Rally Rear Wheel Replacement: adım 2, 1 resimden 1.
    • Slide the plastic side piece off from both sides of the scooter.
    • Two 4 mm screws and 2 side panels are taken out.
    Instead of remove say slide. It is more descriptive.
    Dylan Ruiz - Yanıt
  3. Hover-1 Rally Rear Wheel Replacement: adım 3, 2 resimden 1. Hover-1 Rally Rear Wheel Replacement: adım 3, 2 resimden 2.
    • Use a 4 mm bit extension to push the axle out of the wheel’s center.
    What is the size(diameter) of the axle?
    AverageRedHead - Yanıt
  4. Hover-1 Rally Rear Wheel Replacement: adım 4, 1 resimden 1.
    • Grab the deck of the scooter, and pull the wheel downwards.
    • 2 washers will fall out with the wheel.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cami Lowrey
435 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G2, Regan Winter 2020 Cal Poly, Team S7-G2, Regan Winter 2020 üyesi
CPSU-REGAN-W20S7G2
6 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Where can I buy replacement tires/wheels for the hover-1 rally scooter?
Josh Hatt - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 867
