Ana içeriğe geç
Hover-1 Superstar Battery Replacement
Neye ihtiyacın var
  1. Hover-1 Superstar Battery Replacement, Bottom Case: adım 1, 3 resimden 1. Hover-1 Superstar Battery Replacement, Bottom Case: adım 1, 3 resimden 2. Hover-1 Superstar Battery Replacement, Bottom Case: adım 1, 3 resimden 3.
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
    FixBot'a Sor
    Yorum Ekle
  2. Hover-1 Superstar Battery Replacement: adım 2, 1 resimden 1.
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
    FixBot'a Sor
    Yorum Ekle
  3. Hover-1 Superstar Battery Replacement, Battery: adım 3, 2 resimden 1. Hover-1 Superstar Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Locate the four 14mm screws securing the battery bracket.
    • Remove the screws with a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Hover-1 Superstar Battery Replacement: adım 4, 1 resimden 1.
    • Pull and disconnect the cable connector that is connected to the battery.
    FixBot'a Sor
    Yorum Ekle
  5. Hover-1 Superstar Battery Replacement: adım 5, 1 resimden 1.
    • Pull on the battery until it separates from the hover board. You may need to use some force.
    • Be sure the battery is disconnected before performing this step to avoid electrocution.
    • There will be a loud crack when the battery is removed. This is normal due to the adhesive on the back of the battery.
    • Pull the battery out of the hoverboard. Move wires away from the battery if necessary.
    FixBot'a Sor
    Yorum Ekle
Sonuç
1Rehber Yorum
How do u get a 25.2v battery at for my hover-1
chivitbprince Boonking - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 37
Her zaman: 2,365
