Giriş
In order to access the internal components of the Hover-1 Superstar, the bottom case must first be unscrewed and removed. This guide will explain the process of removing the bottom case from the Hover-1 Superstar.
Neye ihtiyacın var
Flip your Hover-1 Superstar device upside down.
Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
Remove the bottom case. Be careful of the connector holding the case and the device together.
