Ana içeriğe geç
Hover-1 Superstar Front Bumper LED Replacement
Neye ihtiyacın var
  1. Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: adım 1, 3 resimden 1. Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: adım 1, 3 resimden 2. Hover-1 Superstar Front Bumper LED Replacement, Bottom Case: adım 1, 3 resimden 3.
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
    FixBot'a Sor
    Yorum Ekle
  2. Hover-1 Superstar Front Bumper LED Replacement: adım 2, 1 resimden 1.
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
    FixBot'a Sor
    Yorum Ekle
  3. Hover-1 Superstar Front Bumper LED Replacement, Front Bumper LED: adım 3, 1 resimden 1.
    • Grab the wire of the connector you disconnected from the case earlier and slide the entire light out away from the case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 522
