Ana içeriğe geç
Hover-1 Titan Battery Replacement
Neye ihtiyacın var
  1. Hover-1 Titan Battery Replacement, Bottom Right Panel: adım 1, 2 resimden 1. Hover-1 Titan Battery Replacement, Bottom Right Panel: adım 1, 2 resimden 2.
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
  2. Hover-1 Titan Battery Replacement: adım 2, 2 resimden 1. Hover-1 Titan Battery Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Battery Replacement: adım 3, 3 resimden 1. Hover-1 Titan Battery Replacement: adım 3, 3 resimden 2. Hover-1 Titan Battery Replacement: adım 3, 3 resimden 3.
    • Grip the bottom right panel and lift to remove it.
  4. Hover-1 Titan Battery Replacement, Battery: adım 4, 2 resimden 1. Hover-1 Titan Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
  5. Hover-1 Titan Battery Replacement: adım 5, 2 resimden 1. Hover-1 Titan Battery Replacement: adım 5, 2 resimden 2.
    • Remove the bundle of wires from the clip on the top of the battery.
  6. Hover-1 Titan Battery Replacement: adım 6, 2 resimden 1. Hover-1 Titan Battery Replacement: adım 6, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the four 14 mm screws that hold the battery on the device.
  7. Hover-1 Titan Battery Replacement: adım 7, 3 resimden 1. Hover-1 Titan Battery Replacement: adım 7, 3 resimden 2. Hover-1 Titan Battery Replacement: adım 7, 3 resimden 3.
    • Remove the battery out of the hoverboard by lifting the battery then sliding it out from under the wires.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jessica Ouyang
619 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 üyesi
CPSU-WHITE-F18S15G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 54
Her zaman: 1,983
