Ana içeriğe geç
Hover-1 Titan Left Gyroscope Replacement
Neye ihtiyacın var
  1. Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: adım 1, 2 resimden 1. Hover-1 Titan Left Gyroscope Replacement, Bottom Left Panel: adım 1, 2 resimden 2.
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
    FixBot'a Sor
    Yorum Ekle
  2. Hover-1 Titan Left Gyroscope Replacement: adım 2, 2 resimden 1. Hover-1 Titan Left Gyroscope Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
    FixBot'a Sor
    Yorum Ekle
  3. Hover-1 Titan Left Gyroscope Replacement: adım 3, 3 resimden 1. Hover-1 Titan Left Gyroscope Replacement: adım 3, 3 resimden 2. Hover-1 Titan Left Gyroscope Replacement: adım 3, 3 resimden 3.
    • Grip the bottom left panel and lift up to remove.
    FixBot'a Sor
    Yorum Ekle
  4. Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: adım 4, 2 resimden 1. Hover-1 Titan Left Gyroscope Replacement, Left Gyroscope and Motherboard: adım 4, 2 resimden 2.
    • Unplug the battery from the gyroscope by holding the yellow connector and pulling apart.
    FixBot'a Sor
    Yorum Ekle
  5. Hover-1 Titan Left Gyroscope Replacement: adım 5, 3 resimden 1. Hover-1 Titan Left Gyroscope Replacement: adım 5, 3 resimden 2. Hover-1 Titan Left Gyroscope Replacement: adım 5, 3 resimden 3.
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Hover-1 Titan Left Gyroscope Replacement: adım 6, 2 resimden 1. Hover-1 Titan Left Gyroscope Replacement: adım 6, 2 resimden 2.
    • Unplug the bottom right connector by squeezing it and pulling it away from the board.
    FixBot'a Sor
    Yorum Ekle
  7. Hover-1 Titan Left Gyroscope Replacement: adım 7, 2 resimden 1. Hover-1 Titan Left Gyroscope Replacement: adım 7, 2 resimden 2.
    • Unplug the light connector by squeezing it and pulling away from the board.
    FixBot'a Sor
    Yorum Ekle
  8. Hover-1 Titan Left Gyroscope Replacement: adım 8, 2 resimden 1. Hover-1 Titan Left Gyroscope Replacement: adım 8, 2 resimden 2.
    • Unplug the blue and white wires by squeezing the connector and pulling away from the board.
    FixBot'a Sor
    Yorum Ekle
  9. Hover-1 Titan Left Gyroscope Replacement: adım 9, 2 resimden 1. Hover-1 Titan Left Gyroscope Replacement: adım 9, 2 resimden 2.
    • Unplug the small white connector by squeezing it and pulling away from the board.
    FixBot'a Sor
    Yorum Ekle
  10. Hover-1 Titan Left Gyroscope Replacement: adım 10, 2 resimden 1. Hover-1 Titan Left Gyroscope Replacement: adım 10, 2 resimden 2.
    • Unplug the plug in the red connector.
    • The red plug is glued to the board, so this step will require extra force.
    FixBot'a Sor
    Yorum Ekle
  11. Hover-1 Titan Left Gyroscope Replacement: adım 11, 2 resimden 1. Hover-1 Titan Left Gyroscope Replacement: adım 11, 2 resimden 2.
    • Unplug the charging cable connector by squeezing it and pulling it away from the board.
    FixBot'a Sor
    Yorum Ekle
  12. Hover-1 Titan Left Gyroscope Replacement: adım 12, 1 resimden 1.
    • Cut the cable tie.
    • Unplug the remaining wires.
    • The connectors for the remaining wires are in the rubber covers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jessica Ouyang
634 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 üyesi
CPSU-WHITE-F18S15G4
4 Üyeler
10 adet Kılavuz yazıldı
2Kılavuz Yorumları
I’ve got an active broken on the cover not the one to to speaker the other one. Does anyone know where is terminates. I can’t see where it came from. It can only reach the circuit board or the active of the speaker.
Mark - Yanıt Paylaş
Where do you buy the board?
eden11 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 55
Her zaman: 1,668
