Ana içeriğe geç
Hover-1 Titan Power Button Replacement
Neye ihtiyacın var
  1. Hover-1 Titan Power Button Replacement, Bottom Right Panel: adım 1, 2 resimden 1. Hover-1 Titan Power Button Replacement, Bottom Right Panel: adım 1, 2 resimden 2.
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Hover-1 Titan Power Button Replacement: adım 2, 2 resimden 1. Hover-1 Titan Power Button Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
    FixBot'a Sor
    Yorum Ekle
  3. Hover-1 Titan Power Button Replacement: adım 3, 3 resimden 1. Hover-1 Titan Power Button Replacement: adım 3, 3 resimden 2. Hover-1 Titan Power Button Replacement: adım 3, 3 resimden 3.
    • Grip the bottom right panel and lift to remove it.
    FixBot'a Sor
    Yorum Ekle
  4. Hover-1 Titan Power Button Replacement, Power Button: adım 4, 2 resimden 1. Hover-1 Titan Power Button Replacement, Power Button: adım 4, 2 resimden 2.
    • Disconnect the battery by holding the yellow connectors and pulling apart.
    FixBot'a Sor
    Yorum Ekle
  5. Hover-1 Titan Power Button Replacement: adım 5, 3 resimden 1. Hover-1 Titan Power Button Replacement: adım 5, 3 resimden 2. Hover-1 Titan Power Button Replacement: adım 5, 3 resimden 3.
    • Unplug the red and black power button connector on the motherboard by squeezing the connector and pulling away from the board.
    • You can also unplug the light connector to free up your work space.
    FixBot'a Sor
    Yorum Ekle
  6. Hover-1 Titan Power Button Replacement: adım 6, 2 resimden 1. Hover-1 Titan Power Button Replacement: adım 6, 2 resimden 2.
    • Use an adjustable wrench to remove the 14 mm nut holding the button in the shell.
    FixBot'a Sor
    Yorum Ekle
  7. Hover-1 Titan Power Button Replacement: adım 7, 3 resimden 1. Hover-1 Titan Power Button Replacement: adım 7, 3 resimden 2. Hover-1 Titan Power Button Replacement: adım 7, 3 resimden 3.
    • Pull the power button out of the panel.
    • Replace the power button.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Alexander Pham
221 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 üyesi
CPSU-WHITE-F18S15G4
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 42
Her zaman: 1,010
