Ana içeriğe geç
Hover-1 Titan Right Gyroscope Replacement
Neye ihtiyacın var
  1. Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: adım 1, 2 resimden 1. Hover-1 Titan Right Gyroscope Replacement, Bottom Right Panel: adım 1, 2 resimden 2.
    • Flip the hoverboard so the bottom is facing up.
    • The right side is the side that has the power button. There is also an "R" on the metal plate underneath the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Hover-1 Titan Right Gyroscope Replacement: adım 2, 2 resimden 1. Hover-1 Titan Right Gyroscope Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
    FixBot'a Sor
    Yorum Ekle
  3. Hover-1 Titan Right Gyroscope Replacement: adım 3, 3 resimden 1. Hover-1 Titan Right Gyroscope Replacement: adım 3, 3 resimden 2. Hover-1 Titan Right Gyroscope Replacement: adım 3, 3 resimden 3.
    • Grip the bottom right panel and lift to remove it.
    FixBot'a Sor
    Yorum Ekle
  4. Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: adım 4, 2 resimden 1. Hover-1 Titan Right Gyroscope Replacement, Right Gyroscope and Motherboard: adım 4, 2 resimden 2.
    • Unplug the battery from the gyroscope/motherboard by holding the yellow connector and pulling apart.
    FixBot'a Sor
    Yorum Ekle
  5. Hover-1 Titan Right Gyroscope Replacement: adım 5, 3 resimden 1. Hover-1 Titan Right Gyroscope Replacement: adım 5, 3 resimden 2. Hover-1 Titan Right Gyroscope Replacement: adım 5, 3 resimden 3.
    • Remove four 12 mm Phillips #1 head screws from the corners of the green gyroscope/motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. Hover-1 Titan Right Gyroscope Replacement: adım 6, 2 resimden 1. Hover-1 Titan Right Gyroscope Replacement: adım 6, 2 resimden 2.
    • Unplug the bottom left connector by squeezing it and pulling it away from the board.
    FixBot'a Sor
    Yorum Ekle
  7. Hover-1 Titan Right Gyroscope Replacement: adım 7, 2 resimden 1. Hover-1 Titan Right Gyroscope Replacement: adım 7, 2 resimden 2.
    • Unplug the white wires by squeezing the connector and pulling away from the board.
    FixBot'a Sor
    Yorum Ekle
  8. Hover-1 Titan Right Gyroscope Replacement: adım 8, 2 resimden 1. Hover-1 Titan Right Gyroscope Replacement: adım 8, 2 resimden 2.
    • Unplug one set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
    FixBot'a Sor
    Yorum Ekle
  9. Hover-1 Titan Right Gyroscope Replacement: adım 9, 2 resimden 1. Hover-1 Titan Right Gyroscope Replacement: adım 9, 2 resimden 2.
    • Unplug the other set of the red, white, purple, and black wires by squeezing the connector and pulling away from the board.
    FixBot'a Sor
    Yorum Ekle
  10. Hover-1 Titan Right Gyroscope Replacement: adım 10, 1 resimden 1.
    • Cut the cable tie and unplug the remaining wires.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jessica Ouyang
634 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 üyesi
CPSU-WHITE-F18S15G4
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Where can I get the circuit boards for the left and right ?
jfsucher - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 36
Her zaman: 1,746
