Giriş
If the wheel of your hoverboard is damaged or your hoverboard does not spin on one side, use this guide to replace the wheel and motor in the Hover-1 Titan.
Neye ihtiyacın var
Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
3 farklı kişi bu kılavuzu tamamladı.
