Ana içeriğe geç
Hover-1 Titan Wheel and Motor Replacement
Neye ihtiyacın var
  1. Hover-1 Titan Wheel and Motor Replacement, Bottom Left Panel: adım 1, 2 resimden 1. Hover-1 Titan Wheel and Motor Replacement, Bottom Left Panel: adım 1, 2 resimden 2.
    • Flip the hoverboard so the bottom is facing up.
    • The left side is the side that has the charge port. There is also an "L" on the metal plate underneath the wires.
  2. Hover-1 Titan Wheel and Motor Replacement: adım 2, 2 resimden 1. Hover-1 Titan Wheel and Motor Replacement: adım 2, 2 resimden 2.
    • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
    • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
    • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
  3. Hover-1 Titan Wheel and Motor Replacement: adım 3, 3 resimden 1. Hover-1 Titan Wheel and Motor Replacement: adım 3, 3 resimden 2. Hover-1 Titan Wheel and Motor Replacement: adım 3, 3 resimden 3.
    • Grip the bottom left panel and lift up to remove.
  4. Hover-1 Titan Wheel and Motor Replacement, Wheel and Motor: adım 4, 2 resimden 1. Hover-1 Titan Wheel and Motor Replacement, Wheel and Motor: adım 4, 2 resimden 2.
    • Unplug the battery by pulling apart the yellow connectors.
  5. Hover-1 Titan Wheel and Motor Replacement: adım 5, 2 resimden 1. Hover-1 Titan Wheel and Motor Replacement: adım 5, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the four 12mm screws that attach the gyroscope/motherboard to the hoverboard.
  6. Hover-1 Titan Wheel and Motor Replacement: adım 6, 3 resimden 1. Hover-1 Titan Wheel and Motor Replacement: adım 6, 3 resimden 2. Hover-1 Titan Wheel and Motor Replacement: adım 6, 3 resimden 3.
    • Cut the rubber surrounding the yellow wire and pull the rubber apart, exposing the connectors.
  7. Hover-1 Titan Wheel and Motor Replacement: adım 7, 2 resimden 1. Hover-1 Titan Wheel and Motor Replacement: adım 7, 2 resimden 2.
    • Unplug the yellow wires by gripping the wire close to the connectors and pulling apart.
  8. Hover-1 Titan Wheel and Motor Replacement: adım 8, 3 resimden 1. Hover-1 Titan Wheel and Motor Replacement: adım 8, 3 resimden 2. Hover-1 Titan Wheel and Motor Replacement: adım 8, 3 resimden 3.
    • Cut the rubber surrounding the green wire and pull the rubber apart, exposing the connectors.
  9. Hover-1 Titan Wheel and Motor Replacement: adım 9, 2 resimden 1. Hover-1 Titan Wheel and Motor Replacement: adım 9, 2 resimden 2.
    • Unplug the green wires by gripping the wire close to the connectors and pulling apart.
  10. Hover-1 Titan Wheel and Motor Replacement: adım 10, 3 resimden 1. Hover-1 Titan Wheel and Motor Replacement: adım 10, 3 resimden 2. Hover-1 Titan Wheel and Motor Replacement: adım 10, 3 resimden 3.
    • Cut the rubber surrounding the blue wire and pull the rubber apart, exposing the connectors.
  11. Hover-1 Titan Wheel and Motor Replacement: adım 11, 2 resimden 1. Hover-1 Titan Wheel and Motor Replacement: adım 11, 2 resimden 2.
    • Unplug the blue wires by gripping the wire close to the connectors and pulling apart.
  12. Hover-1 Titan Wheel and Motor Replacement: adım 12, 3 resimden 1. Hover-1 Titan Wheel and Motor Replacement: adım 12, 3 resimden 2. Hover-1 Titan Wheel and Motor Replacement: adım 12, 3 resimden 3.
    • Unplug the rainbow connector by squeezing the clips and pulling apart.
  13. Hover-1 Titan Wheel and Motor Replacement: adım 13, 2 resimden 1. Hover-1 Titan Wheel and Motor Replacement: adım 13, 2 resimden 2.
    • Use scissors to cut the zip tie around the group of wires.
  14. Hover-1 Titan Wheel and Motor Replacement: adım 14, 3 resimden 1. Hover-1 Titan Wheel and Motor Replacement: adım 14, 3 resimden 2. Hover-1 Titan Wheel and Motor Replacement: adım 14, 3 resimden 3.
    • Unplug the white wire connector by squeezing the clips and pulling apart.
  15. Hover-1 Titan Wheel and Motor Replacement: adım 15, 2 resimden 1. Hover-1 Titan Wheel and Motor Replacement: adım 15, 2 resimden 2.
    • Use an impact driver with a hex 6 bit to loosen the four 20 mm hex 6 bolts.
    • Wear safety glasses while using the impact driver.
  16. Hover-1 Titan Wheel and Motor Replacement: adım 16, 3 resimden 1. Hover-1 Titan Wheel and Motor Replacement: adım 16, 3 resimden 2. Hover-1 Titan Wheel and Motor Replacement: adım 16, 3 resimden 3.
    • Pull out the loosened screws with your hands and remove the metal plate.
  17. Hover-1 Titan Wheel and Motor Replacement: adım 17, 2 resimden 1. Hover-1 Titan Wheel and Motor Replacement: adım 17, 2 resimden 2.
    • Lift the wheel and motor shaft up and out of the board.
    • The motor shaft is located within the wheel.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Emma Huun
312 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G4, White Fall 2018 Cal Poly, Team S15-G4, White Fall 2018 üyesi
CPSU-WHITE-F18S15G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 26
Son 30 gün: 51
Her zaman: 1,685
