Ana içeriğe geç
Hover-1 Ultra Battery Replacement
Neye ihtiyacın var
  1. Hover-1 Ultra Battery Replacement, Battery: adım 1, 3 resimden 1. Hover-1 Ultra Battery Replacement, Battery: adım 1, 3 resimden 2. Hover-1 Ultra Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Orient the hoverboard so that the pads are facing down.
    • With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board.
    • Carefully remove the shell, lifting directly up.
  2. Hover-1 Ultra Battery Replacement: adım 2, 3 resimden 1. Hover-1 Ultra Battery Replacement: adım 2, 3 resimden 2. Hover-1 Ultra Battery Replacement: adım 2, 3 resimden 3.
    • Remove the 4 screws around the battery on the case using the Phillips #1 screwdriver.
    • Remove the case that houses the battery.
  3. Hover-1 Ultra Battery Replacement: adım 3, 3 resimden 1. Hover-1 Ultra Battery Replacement: adım 3, 3 resimden 2. Hover-1 Ultra Battery Replacement: adım 3, 3 resimden 3.
    • Pinch and pull apart the connecting black and yellow cable.
    • Remove the battery from the hoverboard.
Sonuç
To reassemble your device, follow the instructions in step 1 in reverse order.
Bir başkası bu kılavuzu tamamladı.
Camron Clifton
409 İtibar
3 adet Kılavuz yazıldı
Ekip
UC Davis, Team S7-G5, Lore Fall 2018 UC Davis, Team S7-G5, Lore Fall 2018 üyesi
UCD-LORE-F18S7G5
3 Üyeler
Bir Yorum
Merci pour tous ces conseils précieux, j’ai pu réparer ma batterie de Hoverboard : https://hover-store.fr/batterie-hoverboa...
willfrite71 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 19
Son 30 gün: 61
Her zaman: 7,468
