Ana içeriğe geç
Hover-1 Ultra Charging Port Replacement
Neye ihtiyacın var
  1. Hover-1 Ultra Charging Port Replacement, Charging Port: adım 1, 3 resimden 1. Hover-1 Ultra Charging Port Replacement, Charging Port: adım 1, 3 resimden 2. Hover-1 Ultra Charging Port Replacement, Charging Port: adım 1, 3 resimden 3.
    • Orient the hoverboard so that the pads are facing down.
    • With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the board.
    • Carefully remove the shell, lifting directly up.
  2. Hover-1 Ultra Charging Port Replacement: adım 2, 2 resimden 1. Hover-1 Ultra Charging Port Replacement: adım 2, 2 resimden 2.
    • Using your hands or a crescent wrench, begin removing the charging port.
    • Turn the charging port counter-clockwise to release it from the shell.
  3. Hover-1 Ultra Charging Port Replacement: adım 3, 3 resimden 1. Hover-1 Ultra Charging Port Replacement: adım 3, 3 resimden 2. Hover-1 Ultra Charging Port Replacement: adım 3, 3 resimden 3.
    • Unclip the insulated red and black wires attached to the port from the motherboard
  4. Hover-1 Ultra Charging Port Replacement: adım 4, 3 resimden 1. Hover-1 Ultra Charging Port Replacement: adım 4, 3 resimden 2. Hover-1 Ultra Charging Port Replacement: adım 4, 3 resimden 3.
    • Remove the charging port through the assembly.
    • Place new charging port through the assembly.
    • Clip red and black insulated wires into the motherboard.
Sonuç
To reassemble your device, follow the instructions for step 1 in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Camron Clifton
409 İtibar
3 adet Kılavuz yazıldı
Ekip
UC Davis, Team S7-G5, Lore Fall 2018 UC Davis, Team S7-G5, Lore Fall 2018 üyesi
UCD-LORE-F18S7G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 686
