Ana içeriğe geç
Hover-1 Ultra Power Button Replacement
Neye ihtiyacın var
  1. Hover-1 Ultra Power Button Replacement, Power Button: adım 1, 3 resimden 1. Hover-1 Ultra Power Button Replacement, Power Button: adım 1, 3 resimden 2. Hover-1 Ultra Power Button Replacement, Power Button: adım 1, 3 resimden 3.
    • Orient the hoverboard so that the pads are facing down.
    • With the Phillips #1 screwdriver, remove all 18 of the screws on the underside of the hoverboard.
    • Carefully remove the shell, lifting directly up.
  2. Hover-1 Ultra Power Button Replacement: adım 2, 1 resimden 1.
    • Unscrew the power button using your hands or an adjustable crescent wrench.
    • Turn the power button counter-clockwise to release from the shell.
  3. Hover-1 Ultra Power Button Replacement: adım 3, 3 resimden 1. Hover-1 Ultra Power Button Replacement: adım 3, 3 resimden 2. Hover-1 Ultra Power Button Replacement: adım 3, 3 resimden 3.
    • Unclip the red and black power cables that are attached to the port from the motherboard.
  4. Hover-1 Ultra Power Button Replacement: adım 4, 2 resimden 1. Hover-1 Ultra Power Button Replacement: adım 4, 2 resimden 2.
    • Remove the power button from the hoverboard assembly.
Sonuç
To reassemble your device, follow the instructions for step 1 in reverse order.
Bir başkası bu kılavuzu tamamladı.
Camron Clifton
409 İtibar
3 adet Kılavuz yazıldı
Ekip
UC Davis, Team S7-G5, Lore Fall 2018 UC Davis, Team S7-G5, Lore Fall 2018 üyesi
UCD-LORE-F18S7G5
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 710
