Ana içeriğe geç
Hover-1 XLS Back Seat Light Replacement
Neye ihtiyacın var
    1. Hover-1 XLS Back Seat Light Replacement, Back Seat Light: adım 1, 2 resimden 1. Hover-1 XLS Back Seat Light Replacement, Back Seat Light: adım 1, 2 resimden 2.
      • Remove the seat by removing the six 16mm screws with a Phillips #2 screwdriver.
      • Remember that the seat is still connected by the wiring once you unscrew it. Pulling too hard can damage the connector.
      FixBot'a Sor
      Yorum Ekle
    2. Hover-1 XLS Back Seat Light Replacement: adım 2, 3 resimden 1. Hover-1 XLS Back Seat Light Replacement: adım 2, 3 resimden 2. Hover-1 XLS Back Seat Light Replacement: adım 2, 3 resimden 3.
      • Disconnect the wires by pushing the levers on either side of the connector and on top.
      • Remove the seat from the bike.
      FixBot'a Sor
      Yorum Ekle
    3. Hover-1 XLS Back Seat Light Replacement: adım 3, 1 resimden 1.
      • Use a Phillips #2 screwdriver to remove the four 10mm screws on the bottom of the back seat.
      FixBot'a Sor
      Yorum Ekle
    4. Hover-1 XLS Back Seat Light Replacement: adım 4, 2 resimden 1. Hover-1 XLS Back Seat Light Replacement: adım 4, 2 resimden 2.
      • Pull the light from behind the bottom of the seat frame. Pull the wiring all the way through.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekip
Cal Poly, Team S1-G2, White Winter 2019 Cal Poly, Team S1-G2, White Winter 2019 üyesi
CPSU-WHITE-W19S1G2
3 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 765
