Ana içeriğe geç
Hover-1 XLS Battery Replacement
Neye ihtiyacın var
  1. Hover-1 XLS Battery Replacement, Battery: adım 1, 3 resimden 1. Hover-1 XLS Battery Replacement, Battery: adım 1, 3 resimden 2. Hover-1 XLS Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the four, 12mm Hex #3 screws located on the bottom half of the battery compartment.
    • There are four screws that need to remove. Two on one side and the two on the opposite side.
    FixBot'a Sor
    Yorum Ekle
  2. Hover-1 XLS Battery Replacement: adım 2, 3 resimden 1. Hover-1 XLS Battery Replacement: adım 2, 3 resimden 2. Hover-1 XLS Battery Replacement: adım 2, 3 resimden 3.
    • Remove the adhesive holding the wires tightly.
    • You can use a sharp object to score the adhesive before pulling.
    • Pull on both sides of the wire connections.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jonathan Hidalgo
659 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G2, White Winter 2019 Cal Poly, Team S1-G2, White Winter 2019 üyesi
CPSU-WHITE-W19S1G2
3 Üyeler
13 adet Kılavuz yazıldı
17Kılavuz Yorumları
That looks easy enough to do. My problem is finding a replacement battery. Do you have any idea where they are available?
David Schultze - Yanıt Paylaş
David did you happen to find one? Please let me know I've been looking for one
Michael Hawk - Yanıt Paylaş
If anyone find a 1:1 replacement battery for this, or at the very least a wiring diagram, please post it as it's near impossible to find anything on this thing in 2022.
GutZ Era - Yanıt Paylaş
So the yellow and a red are for the ignition and the other red and black ig is a standard ground and positive with the white being I think the temperature sensore wire. Hope this helps also trying to find a replacement and may try wiring one up.
Batman and King - Yanıt Paylaş
Hi, where can you find the battery replacement? I have my scooter and the battery needs to be replaced.
Mary - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 41
Son 30 gün: 221
Her zaman: 14,357
