Ana içeriğe geç
Hover-1 XLS Front Wheel Replacement
Neye ihtiyacın var
  1. Hover-1 XLS Front Wheel Replacement, Front Brake: adım 1, 3 resimden 1. Hover-1 XLS Front Wheel Replacement, Front Brake: adım 1, 3 resimden 2. Hover-1 XLS Front Wheel Replacement, Front Brake: adım 1, 3 resimden 3.
    • Remove the two, 23 mm Hex #5 screws holding the brake to the bike.
    • Slide the brake mechanism off and turn it upside down to reveal the screw holding the brake wire.
  2. Hover-1 XLS Front Wheel Replacement: adım 2, 1 resimden 1.
    • Remove the one, 14 mm Hex #4 screw pushing down the brake wire to the brake mechanism on the bottom.
  3. Hover-1 XLS Front Wheel Replacement: adım 3, 2 resimden 1. Hover-1 XLS Front Wheel Replacement: adım 3, 2 resimden 2.
    • Remove the side screw holding the brake wire and mechanism together with your hands.
    • Slide the brake mechanism off from the brake wire.
  4. Hover-1 XLS Front Wheel Replacement, Front Wheel: adım 4, 2 resimden 1. Hover-1 XLS Front Wheel Replacement, Front Wheel: adım 4, 2 resimden 2.
    • Remove the two, 16 mm Hex #4 screws on both of the hub caps in the front wheel.
    • There are two hub caps on the front wheel. Make sure to remove two screws for both hub caps.
  5. Hover-1 XLS Front Wheel Replacement: adım 5, 2 resimden 1. Hover-1 XLS Front Wheel Replacement: adım 5, 2 resimden 2.
    • Using an adjustable spanner wrench, rotate the 165 mm bolt counter-clockwise to remove.
  6. Hover-1 XLS Front Wheel Replacement: adım 6, 3 resimden 1. Hover-1 XLS Front Wheel Replacement: adım 6, 3 resimden 2. Hover-1 XLS Front Wheel Replacement: adım 6, 3 resimden 3.
    • After removing the first bolt, the second bolt located on the other side of the wheel will be able to be take off by hand.
    • Pull the wheel and bike in opposite directions to remove the wheel.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jonathan Hidalgo
596 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G2, White Winter 2019 Cal Poly, Team S1-G2, White Winter 2019 üyesi
CPSU-WHITE-W19S1G2
3 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
How do I get in touch with customer service for parts?
tried filling out the form on computer and phone as well tablet and it says error.
fox_Jayson@yahoo.com
please reach out
petrasherbin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 35
Her zaman: 1,241
