Ana içeriğe geç
How To Clean Nikon Coolpix S30 Lens
Neye ihtiyacın var
    1. How To Clean Nikon Coolpix S30 Lens, Batteries: adım 1, 2 resimden 1. How To Clean Nikon Coolpix S30 Lens, Batteries: adım 1, 2 resimden 2.
      • Slide the battery cover to the right.
      • The hinge is on the left side of the cover which will allow the cover to stay attached.
      FixBot'a Sor
      Yorum Ekle
    2. How To Clean Nikon Coolpix S30 Lens: adım 2, 2 resimden 1. How To Clean Nikon Coolpix S30 Lens: adım 2, 2 resimden 2.
      • Slide the second cover (yellow) to the right (similar to the outer cover). This will allow the batteries to be exposed.
      FixBot'a Sor
      Yorum Ekle
    3. How To Clean Nikon Coolpix S30 Lens: adım 3, 1 resimden 1.
      • Remove the batteries by gently tipping the camera.
      FixBot'a Sor
      Yorum Ekle
    1. How To Clean Nikon Coolpix S30 Lens, How To Clean Nikon Coolpix S30 Lens: adım 4, 1 resimden 1.
      • Remove the four screws the hold the back of the case to the rest of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. How To Clean Nikon Coolpix S30 Lens: adım 5, 1 resimden 1.
      • Remove the left screw from the bottom of the camera first. This can be done using the same T5 tip.
      • Unscrew the screw on the right using a different attachment: PH000 (it is a small Phillip's head)
      FixBot'a Sor
      Yorum Ekle
    3. How To Clean Nikon Coolpix S30 Lens: adım 6, 1 resimden 1.
      • Remove back case from the rest of the camera carefully.
      FixBot'a Sor
      Yorum Ekle
    4. How To Clean Nikon Coolpix S30 Lens: adım 7, 1 resimden 1.
      • Remove the three screws the secure the motherboard to the front case.
      FixBot'a Sor
      Yorum Ekle
    5. How To Clean Nikon Coolpix S30 Lens: adım 8, 2 resimden 1. How To Clean Nikon Coolpix S30 Lens: adım 8, 2 resimden 2.
      • Remove the motherboard from the front case.
      • Leave the red and black wire attached but lay the piece in front of the case.
      FixBot'a Sor
      Yorum Ekle
    6. How To Clean Nikon Coolpix S30 Lens: adım 9, 2 resimden 1. How To Clean Nikon Coolpix S30 Lens: adım 9, 2 resimden 2.
      • Wipe the lens and the clear plastic on the front case to remove debris.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Courtney Weida
167 İtibar
1 Kılavuz yazıldı
Ekip
Penn State, Team 2-4, Kaschak Winter 2015 Penn State, Team 2-4, Kaschak Winter 2015 üyesi
PSU-KASCHAK-W15S2G4
4 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
The first three steps are redundant because you already included the prerequisite guide for removal of the batteries.
Dylan Keiter - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 2,095
