Ana içeriğe geç
How To Fix A Hole In Khaki Pants
Neye ihtiyacın var
  1. How To Fix A Hole In Khaki Pants, How To Fix A Hole In Khaki Pants: adım 1, 1 resimden 1.
    • Examine the damaged area.
    • Make sure to clean all the debris from the tear.
  2. How To Fix A Hole In Khaki Pants: adım 2, 1 resimden 1.
    • Flip your pants inside out.
  3. How To Fix A Hole In Khaki Pants: adım 3, 1 resimden 1.
    • Pinch hole together.
    • Make sure there is no gaps showing.
  4. How To Fix A Hole In Khaki Pants: adım 4, 1 resimden 1.
    • Pin needle and thread through pants.
    • Use more thread than needed so you will have enough.
    • Make sure your hand is not directly behind the needle where you are poking. This will prevent you from pricking yourself.
  5. How To Fix A Hole In Khaki Pants: adım 5, 2 resimden 1. How To Fix A Hole In Khaki Pants: adım 5, 2 resimden 2.
    • Pull needle and thread through pants until there is only 2 inches of thread left.
    • Tie a knot at the end of the remaining 2 inches.
    • It can be any measurement, but 2 inches makes it easier to tie a knot without wasting too much thread.
  6. How To Fix A Hole In Khaki Pants: adım 6, 2 resimden 1. How To Fix A Hole In Khaki Pants: adım 6, 2 resimden 2.
    • Take the needle and pin it through right next to the previous spot.
    • Pull all the way through until thread is tight.
    • Repeat this process until you reach the end of the hole.
  7. How To Fix A Hole In Khaki Pants: adım 7, 1 resimden 1.
    • Wrap the thread three times around the needle.
    • Pull the needle until the thread is tight.
    • This will tie a knot at the end.
  8. How To Fix A Hole In Khaki Pants: adım 8, 1 resimden 1.
    • Take the scissors and cut the excess string remaining.
  9. How To Fix A Hole In Khaki Pants: adım 9, 1 resimden 1.
    • Now put your khaki pants on because they are now wearable again and practically new!
Sonuç
Now your old ripped pants look practically new and you can begin wearing them again.
6 farklı kişi bu kılavuzu tamamladı.
Calvin Roth
291 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-1, Green Fall 2015 Cal Poly, Team 17-1, Green Fall 2015 üyesi
CPSU-GREEN-F15S17G1
4 Üyeler
5 adet Kılavuz yazıldı
5 Yorum
it's 100% not ok...... i con do it so 99% ok
Shafikahmed - Yanıt
and 100% maching
Shafikahmed - Yanıt
Iam shafik i can't do it's and 100% maching
Shafikahmed - Yanıt
What about if you’re in school and your pants rip?
EMMA MILLER - Yanıt
is it smooth when you fix it? i use these for school and dont want it to show
JORDI ZAMUDIO - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 31
Son 30 gün: 141
Her zaman: 51,459
