Ana içeriğe geç
Giriş
This guide is intended to show you how to fix a jammed rocket cart that is unable to open properly.
Using a flat-edge screwdriver and pliers, I’ll show you a technique that allows you to fix the locking mechanism that is preventing the jammed rocket cart from opening.
Parçalar
Hiçbir parça belirtilmedi.
  1. The rocket cart is not able to open due to the jammed locking mechanism. The rocket cart is not able to open due to the jammed locking mechanism.
    • The rocket cart is not able to open due to the jammed locking mechanism.
  2. Gently clean the locking mechanism with wet wipes. Make sure there is no debris on the locking latch.
    • Gently clean the locking mechanism with wet wipes.
    • Make sure there is no debris on the locking latch.
  3. Hold a flathead screwdriver on the opposite side of the locking latch.
    • Hold a flathead screwdriver on the opposite side of the locking latch.
    • Wedge the screwdriver in between the locking mechanism and hold it still.
  4. Firmly grip the long circular locking latch with a set of pliers.
    • Firmly grip the long circular locking latch with a set of pliers.
  5. At the same time, wedge the screwdriver behind the locking mechanism.
    • At the same time, wedge the screwdriver behind the locking mechanism.
    • Simultaneously pull the long circular locking latch with the pliers to fix the jam.
  6. Pull the long circular latch towards you to release the metal holder bracket. Pull the long circular latch towards you to release the metal holder bracket.
    • Pull the long circular latch towards you to release the metal holder bracket.
  7. Align the metal rod on the side to the bottom, connecting them both together. This will allow the metal holder to be connected and secure on the rocket cart. This will allow the metal holder to be connected and secure on the rocket cart.
    • Align the metal rod on the side to the bottom, connecting them both together.
    • This will allow the metal holder to be connected and secure on the rocket cart.
  8. Pull the circular long latch towards you on the top metal holder bracket. Pull the circular long latch towards you on the top metal holder bracket.
    • Pull the circular long latch towards you on the top metal holder bracket.
  9. Align the metal rods on the side together so they connect for the top metal bracket holder. Align the metal rods on the side together so they connect for the top metal bracket holder. Align the metal rods on the side together so they connect for the top metal bracket holder.
    • Align the metal rods on the side together so they connect for the top metal bracket holder.
  10. Pull down the safety latch to make sure the rocket cart is in secure position. Pull down the safety latch to make sure the rocket cart is in secure position.
    • Pull down the safety latch to make sure the rocket cart is in secure position.
  11. The rocket cart is now unjammed and back to working condition. The rocket cart is now unjammed and back to working condition.
    • The rocket cart is now unjammed and back to working condition.
Bitiş Çizgisi
Turab Gardezi
193 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 163
