Giriş
Learn how to repair a broken wicker chair seat!
If your wicker chair seat is broken or has cracks, it may be the result of regular use or simply aging. Use this guide to restore your wicker chair seat, making it look as good as new and stable enough to sit on again. This method works for most wicker furniture that uses the same weaving process.
Wicker reed plays a crucial role in the structure of a wicker chair seat, helping to maintain its shape and stability. Soaking the reed in water makes it flexible and malleable, allowing it to be easily shaped and woven between itself and the metal frame of the chair, creating a strong and durable structure as it dries.
Neye ihtiyacın var
Soak the reed in a bowl of room temperature water for 15 minutes.
When you have completed a few passes, return to the beginning of your project and find the two inches of reed left unwoven.
Wrap the end of the reed around the rail twice.
Take the remaining reed and weave it into a gap in the existing weaving; it should stay in place.
Continue weaving the long end of the reed.
Bir başkası bu kılavuzu tamamladı.
