Ana içeriğe geç
How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan
Neye ihtiyacın var
  1. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan, How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: adım 1, 1 resimden 1.
    • remove the three Phillips screws under the fan closest to the video ports of the card
  2. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: adım 2, 1 resimden 1.
    • Lift the fan out(will be attached to a small cord but gets out of the way well) and shim a small cushion under the center circle, between the aluminum cooling fins and the plastic. I used electric tape, rolling it, sticky side in, to form about a 6 layer small square of tape. It shimmed in nicely.
  3. How To Fix GIGABYTE GV-R785OC-2GD Radeon HD 7850 Noisy Fan: adım 3, 1 resimden 1.
    • Reassemble and re-install the card into your computer. It should stop the vibration.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Matthew Johnson
392 İtibar
1 Kılavuz yazıldı
Bir Yorum
Can you post a picture showing how its fit in the fins?
Gustavo Horta - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 21
Her zaman: 8,325
