Ana içeriğe geç
How To Fix Sticky Keyboard Keys on a MacBook
Neye ihtiyacın var
  1. How To Fix Sticky Keyboard Keys on a MacBook, How To Fix Sticky Keyboard Keys on a MacBook: adım 1, 1 resimden 1.
    • Before getting started make sure to completely turn off your computer.
    • Click on the apple in the upper left-hand corner of your computer screen. A drop down menu will appear.
    • Click "shut down".
  2. How To Fix Sticky Keyboard Keys on a MacBook: adım 2, 3 resimden 1. How To Fix Sticky Keyboard Keys on a MacBook: adım 2, 3 resimden 2. How To Fix Sticky Keyboard Keys on a MacBook: adım 2, 3 resimden 3.
    • Dip a q-tip in isopropanol (isopropyl alcohol), and wipe around each sticky key.
    • Make sure the q-tip is damp, not dripping.
    • You may need multiple q-tips, as they get pretty dirty.
  3. How To Fix Sticky Keyboard Keys on a MacBook: adım 3, 1 resimden 1.
    • Use a toothpick to remove crumbs or debris from under the sticky keys.
  4. How To Fix Sticky Keyboard Keys on a MacBook: adım 4, 1 resimden 1.
    • Now test out your keys. If they are still sticky continue on to Step 5.
  5. How To Fix Sticky Keyboard Keys on a MacBook: adım 5, 3 resimden 1. How To Fix Sticky Keyboard Keys on a MacBook: adım 5, 3 resimden 2. How To Fix Sticky Keyboard Keys on a MacBook: adım 5, 3 resimden 3.
    • Use a spudger or plastic opening tool to pry up sticky keys.
    • Insert the spudger under the side of a key.
    • Lift up.
    • Use your fingers to twist the key off.
    • To avoid damaging your laptop, use a spudger or plastic opening tool rather than the butter knife shown in the image.
  6. How To Fix Sticky Keyboard Keys on a MacBook: adım 6, 2 resimden 1. How To Fix Sticky Keyboard Keys on a MacBook: adım 6, 2 resimden 2.
    • When you are removing a key if one or both of these white plastic pieces come off the key board, don't worry. They are called key carriers and are very easy to put back on.
    • If one part of the carrier is still in the keyboard, remove it so you have both in you hands.
    • Look at the second picture and align the two piece then push them together. There should be a soft clicking sound.
    • In the same alignment as the second picture, place the carrier in the spot on the keyboard where it came off and press firmly into place.
  7. How To Fix Sticky Keyboard Keys on a MacBook: adım 7, 2 resimden 1. How To Fix Sticky Keyboard Keys on a MacBook: adım 7, 2 resimden 2.
    • Put soap and warm water in a cup.
    • As you remove the keys, put them in the soapy water.
    • Let the keys soak for 10 minutes.
  8. How To Fix Sticky Keyboard Keys on a MacBook: adım 8, 1 resimden 1.
    • Wipe down your keyboard with q-tips damp with rubbing alcohol.
  9. How To Fix Sticky Keyboard Keys on a MacBook: adım 9, 2 resimden 1. How To Fix Sticky Keyboard Keys on a MacBook: adım 9, 2 resimden 2.
    • Optional: If your keys are particularly sticky use rubbing alcohol and a q-tip to wipe the back of the keys.
    • Dry the keys completely with a paper towel.
  10. How To Fix Sticky Keyboard Keys on a MacBook: adım 10, 2 resimden 1. How To Fix Sticky Keyboard Keys on a MacBook: adım 10, 2 resimden 2.
    • Pop the keys back on:
    • First align the key and press firmly into place.
    • Then, move your finger side to side until you hear a double clicking sound.
Sonuç
Hopefully now you've fixed the sticky keys problem on your MacBook. It's a good idea to do light cleaning and maintenance on your keyboard from time to time. iFixit's Electronics Cleaning Bundle and Precision Cleaning Kit are great for avoiding sticky keys and generally keeping the insides and outsides of your electronics spick and span.
188 farklı kişi bu kılavuzu tamamladı.
Lilly Paul
2.261 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 24-6, Green Winter 2015 Cal Poly, Team 24-6, Green Winter 2015 üyesi
CPSU-GREEN-W15S24G6
4 Üyeler
16 adet Kılavuz yazıldı
58Kılavuz Yorumları
YOU ROCK THANK YOU
(I'm going to type "S" a few times to demonstrate how well this helped me!
SSSSSsssssssssssssSSSSSSSSSSSSSSSsssssSSS
Victoria Patterson - Yanıt
Ugh it frustrates me that the author doesn't comprehensibly guide you through the complexities of taking keys off and on your keyboard. They are delicate and fit together elegantly. You should really elaborate before going and telling people to yank their keys off.
Aeron Ebbs - Yanıt
I disagree. He specified what to use, how to put them back on, etc. It's clear and precise!
Anyway I'm going to try this tonight so we'll see how it goes!
kaymay -
Great help - thx!
Kate - Yanıt
I'd just buy a new keyboard and fit it. Would take a lot less time!
Kevin Gill - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 76
Son 7 gün: 584
Son 30 gün: 3,590
Her zaman: 1,095,048
