Ana içeriğe geç
How To Fix Vertical Lines On An iPhone Screen After Replacement
Neye ihtiyacın var
  1. How To Fix Vertical Lines On An iPhone Screen After Replacement, Electro-Static Discharge (ESD): adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Mat
    $24.99
    • ESD is a common culprit behind display malfunction.
    • Ground yourself and your device to discharge any built up static charge before repairing your phone. The best way to do this is to use an anti-static mat and wear an anti-static wrist strap.
  2. How To Fix Vertical Lines On An iPhone Screen After Replacement, Check the Connection: adım 2, 3 resimden 1. How To Fix Vertical Lines On An iPhone Screen After Replacement, Check the Connection: adım 2, 3 resimden 2. How To Fix Vertical Lines On An iPhone Screen After Replacement, Check the Connection: adım 2, 3 resimden 3.
    • Check the display connections on the cables and the logic board. Dirt, dust or debris can cause a faulty connection and should be cleaned with a soft brush and high concentration isopropyl alcohol (at least 90%). Inspect the connectors and clean as necessary.
    • Isopropyl alcohol is a mild skin and eye irritant. Use gloves and eye protection while working with isopropyl alcohol.
  3. How To Fix Vertical Lines On An iPhone Screen After Replacement, Damaged IC Connector: adım 3, 1 resimden 1.
    • The display has an IC that could be damaged. Check particularly on the upper left and right corners. Any signs of damage indicate the part is defective and needs to be replaced with a new one.
Sonuç
Screens are fragilé (it must be Italian)
130 farklı kişi bu kılavuzu tamamladı.
Matt Zieminski
48.354 İtibar
28 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.610 adet Kılavuz yazıldı
9Kılavuz Yorumları
i had a same problem so can someone sent me the video so that video will help me a lot thanks
Suman Biswa - Yanıt
i have 4he same problem, mines worse, soon as i turn it on verticle lines its bad you cannot see any thing only lines.. brand new screen with lcd, its not working!!! any solutions? im thinking of o new logic board…
jubonygill - Yanıt
I had the same problem when removing and installing an iPhone 6 plus battery. After connecting all four flex cables to the mother board the phone either would not boot up or there were vertical lines on the display. Basics, basics, basics……unplug battery connector. Unplug all four flex cable connectors. Re-attach all four flex cable connectors, then connect battery flex cable. After installing both metal shields and closing the phone it booted up properly and worked just like new. Viola!
bassinbill42 - Yanıt
Did you have any problems after doing that to your phone? Or does it still have the lines?
sscorpion34 -
How to fix the vertical lines camera on iPhone 6
Renz Mendi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 75
Son 30 gün: 357
Her zaman: 470,310
