Ana içeriğe geç
How To Fix a Broken Lipstick
Neye ihtiyacın var
  1. How To Fix a Broken Lipstick, How To Fix a Broken Lipstick: adım 1, 2 resimden 1. How To Fix a Broken Lipstick, How To Fix a Broken Lipstick: adım 1, 2 resimden 2.
    • Prepare a clean working space.
    • Use a gloved hand and separate the broken off piece of the lipstick from the rest of the tube (only if it is not a clean break).
  2. How To Fix a Broken Lipstick: adım 2, 2 resimden 1. How To Fix a Broken Lipstick: adım 2, 2 resimden 2.
    • Twist the base so that the lipstick is fully visible.
  3. How To Fix a Broken Lipstick: adım 3, 2 resimden 1. How To Fix a Broken Lipstick: adım 3, 2 resimden 2.
    • Use the toothpick to clean and level both ends of the broken lipstick.
  4. How To Fix a Broken Lipstick: adım 4, 2 resimden 1. How To Fix a Broken Lipstick: adım 4, 2 resimden 2.
    • Hold a flame over both ends of the lipstick for 2 seconds, or until a top layer is melted.
    • Use caution when working with an open flame and always be aware of your surroundings.
  5. How To Fix a Broken Lipstick: adım 5, 1 resimden 1.
    • Press the ends of the broken pieces back together.
  6. How To Fix a Broken Lipstick: adım 6, 1 resimden 1.
    • Using a flame, melt the pieces together to form a bond.
  7. How To Fix a Broken Lipstick: adım 7, 1 resimden 1.
    • Using a toothpick, smooth out the attachment site.
  8. How To Fix a Broken Lipstick: adım 8, 1 resimden 1.
    • Wait 1 hour for lipstick to set before application.
Sonuç
In order to save time, you can place tube in the fridge for faster results.
Bir başkası bu kılavuzu tamamladı.
Graciana Wood
147 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team 22-6, Rauch Spring 2016 Texas Tech, Team 22-6, Rauch Spring 2016 üyesi
TTU-RAUCH-S16S22G6
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 21
Her zaman: 1,769
