Ana içeriğe geç
How To Fix a Jammed Box Cutter
Neye ihtiyacın var
  1. How To Fix a Jammed Box Cutter, How To Fix a Jammed Box Cutter: adım 1, 3 resimden 1. How To Fix a Jammed Box Cutter, How To Fix a Jammed Box Cutter: adım 1, 3 resimden 2. How To Fix a Jammed Box Cutter, How To Fix a Jammed Box Cutter: adım 1, 3 resimden 3.
    • Using a Phillips head screwdriver, unscrew the screw on the box cutter.
    • Remove the top part of the box cutter.
    FixBot'a Sor
    Yorum Ekle
  2. How To Fix a Jammed Box Cutter: adım 2, 3 resimden 1. How To Fix a Jammed Box Cutter: adım 2, 3 resimden 2. How To Fix a Jammed Box Cutter: adım 2, 3 resimden 3.
    • Caution: Sharp Object Involved
    • Pick up the blade.
    • Separate the blade from the trigger.
    FixBot'a Sor
    Yorum Ekle
  3. How To Fix a Jammed Box Cutter: adım 3, 3 resimden 1. How To Fix a Jammed Box Cutter: adım 3, 3 resimden 2. How To Fix a Jammed Box Cutter: adım 3, 3 resimden 3.
    • Look for the sliding bar and circle which will be located towards the end of the box cutter.
    • Place the trigger aligning with the sliding bar and the circle in the middle of the box cutter.
    • Apply pressure with your finger onto the magnetic part of the trigger to secure placement.
    FixBot'a Sor
    Yorum Ekle
  4. How To Fix a Jammed Box Cutter: adım 4, 2 resimden 1. How To Fix a Jammed Box Cutter: adım 4, 2 resimden 2.
    • Carefully pick up the blade and identify the left hook of the blade and identify the hook of the trigger.
    • Align the hook from the blade on top of the trigger hook.
    FixBot'a Sor
    Yorum Ekle
  5. How To Fix a Jammed Box Cutter: adım 5, 2 resimden 1. How To Fix a Jammed Box Cutter: adım 5, 2 resimden 2.
    • Place the box cutter back together.
    FixBot'a Sor
    Yorum Ekle
  6. How To Fix a Jammed Box Cutter: adım 6, 2 resimden 1. How To Fix a Jammed Box Cutter: adım 6, 2 resimden 2.
    • Hand tightly screw the screw back into the box cutter.
    • Finish off screwing the screw into the box cutter with the screw driver.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Yailene
133 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 37
Son 30 gün: 111
Her zaman: 3,135
