Ana içeriğe geç
How To Fix a Torn Book Page
Neye ihtiyacın var
  1. How To Fix a Torn Book Page, How To Fix a Torn Book Page: adım 1, 1 resimden 1.
    • Lay out all of the equipment needed for the repair.
  2. How To Fix a Torn Book Page: adım 2, 1 resimden 1.
    • Place one piece of wax paper behind the torn page.
    • The wax paper is used to protect the other pages from the glue.
  3. How To Fix a Torn Book Page: adım 3, 1 resimden 1.
    • Be very careful in aligning the torn piece with the page, as realignment after gluing will be difficult.
    • Make sure to align the torn pieces precisely. Placing them too closely or too far apart may create an issue in reading the pages later.
    • Align the torn pieces, so they connect the images/text accurately and neatly.
    • You may use a clamp to hold the torn pieces together to make gluing easier.
  4. How To Fix a Torn Book Page: adım 4, 3 resimden 1. How To Fix a Torn Book Page: adım 4, 3 resimden 2. How To Fix a Torn Book Page: adım 4, 3 resimden 3.
    • Do not apply too much glue, only enough to evenly cover the tear between the page and the torn piece.
    • Remove any excess glue to prevent the pages from sticking to the wax paper.
    • Grab the fabric glue and squeeze a line of glue all the way along the crevice (tear).
    • Use a small paintbrush to apply a moderate amount of glue along the edges of the ripped areas.
  5. How To Fix a Torn Book Page: adım 5, 1 resimden 1.
    • Place the second sheet of wax paper on top of the page you just glued.
    • Be careful when placing the wax paper on top of the wet glue. Moving the wax paper around will make the glue smear.
  6. How To Fix a Torn Book Page: adım 6, 1 resimden 1.
    • Wrap the closed book with several rubber bands to squeeze and compress during drying time.
  7. How To Fix a Torn Book Page: adım 7, 2 resimden 1. How To Fix a Torn Book Page: adım 7, 2 resimden 2.
    • You can also use several books or other heavy items to add extra weight.
  8. How To Fix a Torn Book Page: adım 8, 2 resimden 1. How To Fix a Torn Book Page: adım 8, 2 resimden 2.
    • Let the glue dry for 6 hours minimum to ensure that it dries completely.
    • Carefully peel the top sheet of wax paper first, and then remove the bottom one afterwards.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Thanks for article!
Alex White - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 74
Son 30 gün: 330
Her zaman: 9,619
