• Qualcomm is one of the most popular names all around the world due to its chipsets which uses for many smartphone manufacturers. There are the different flash tool available different devices such as Samsung Odin for Samsung devices. But the specialty of the Qualcomm QPST is that it is compatible with many devices from different manufacturers.
    • The main purpose of the firmware flashing is to flash a Custom ROM or the Stock firmware into a smartphone or tablet devices. Firmware act as a middleman of a device. Simply it creates a connection between the hardware between the operating system and the hardware of a smartphone.
    • Facts To Remember Backup all your valuable data. You can use a PC or internet to backup all your important data.
    Yorum Ekle
    • Here are the QPSt flash tool Download Requirements
    • QPST flash comes as an installer package. So you need to download the ZIP file and extract it in your PC in order to install it. Compatible With Windows 7,8,8.1, 10 platforms. To execute the flashing you are supposed to connect your mobile to the PC. In that case, you have to install necessary device USB drivers in your PC before connecting it.
    • a Proper USB cable to create the bridge connection between devices. Download a firmware file you wish to install in your mobile. That is all that you have to collect to use this tiny tool.
    Yorum Ekle
    • Go to C/System files/ Qualcomm/ QPST/ bin folder and find the file available as Config. there. Download QPST Flash Tool Here.
    Yorum Ekle
    • Now take the USB cable and connect your mobile to the PC.
    Yorum Ekle
  1. Spread Fixmas Cheer
    Get $12 off your purchase of $50 or more with code FIXMAS12
    Spread Fixmas Cheer
    • Open the config file.
    Yorum Ekle
    • Once the Configuration dialog box launched to find the tab named as Ports. Once you click on it you will see a line of details there.
    Yorum Ekle
    • In that same dialog box you will see a tab name as Starts Clients. Click on it. Once you click on it a list of the menu will appear. Select the option named as Software download.
    Yorum Ekle
    • Then another dialog box will appear as QPST Software Download.
    Yorum Ekle
    • Use the browse button available there to locate the firmware you already downloaded into your PC. Click on it start the Flash process.
    Yorum Ekle
    • Click on it start the Flash process. That is all and once it completed to the 100% disconnect the device restart it. Hope the guide will helpful for you.Good Luck.
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joy merryman
181 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 6
Her zaman: 19
