Ana içeriğe geç
How To Install Universal Fit LED Daytime Running Lights
Neye ihtiyacın var
  1. How To Install Universal Fit LED Daytime Running Lights, Philips Style LED Daytime Running Lights Upgrade: adım 1, 1 resimden 1.
    • Insert the wire into the bracket.
    FixBot'a Sor
    Yorum Ekle
  2. How To Install Universal Fit LED Daytime Running Lights: adım 2, 1 resimden 1.
    • Mount the bracket. Since this is universal fit, you can mount it anywhere you'd like.
    FixBot'a Sor
    Yorum Ekle
  3. How To Install Universal Fit LED Daytime Running Lights: adım 3, 1 resimden 1.
    • After mounting the bracket, you can lock the LED daytime running light on the bracket.
    FixBot'a Sor
    Yorum Ekle
  4. How To Install Universal Fit LED Daytime Running Lights: adım 4, 2 resimden 1. How To Install Universal Fit LED Daytime Running Lights: adım 4, 2 resimden 2.
    • Connect the wires and route the wires up and near the fuse box.
    • Use zip ties to tie the wire along the bumper.
    FixBot'a Sor
    Yorum Ekle
  5. How To Install Universal Fit LED Daytime Running Lights: adım 5, 2 resimden 1. How To Install Universal Fit LED Daytime Running Lights: adım 5, 2 resimden 2.
    • Find the ACC in your fuse box and tap the red wire there.
    • You can find the ACC location using an electronic meter by clamping the black wire to the battery negative or ground.
    • When you find ACC, tap the red wires to the blade of the fuse and insert it back.
    FixBot'a Sor
    Yorum Ekle
  6. How To Install Universal Fit LED Daytime Running Lights: adım 6, 1 resimden 1.
    • Tap the black wire to battery negative.
    FixBot'a Sor
    Yorum Ekle
  7. How To Install Universal Fit LED Daytime Running Lights: adım 7, 3 resimden 1. How To Install Universal Fit LED Daytime Running Lights: adım 7, 3 resimden 2. How To Install Universal Fit LED Daytime Running Lights: adım 7, 3 resimden 3.
    • Test to make sure everything works and enjoy your new universal fit Philips Style LED Daytime Running Lights.
    FixBot'a Sor
    Yorum Ekle
Sonuç
As you can see, installation isn't complicated and if you follow the directions accordingly, you'll be on your way to new LED daytime running lights in no time.
21 farklı kişi bu kılavuzu tamamladı.
Eric Wu
3.600 İtibar
23 adet Kılavuz yazıldı
11Kılavuz Yorumları
Useful information shared. Thanks for giving us nice info. Fantastic walk through. I appreciate this post and here is my link
http://optixautolabs.com/
Calvin Macaraeg - Yanıt Paylaş
Useful info. Thanks
grant.edson - Yanıt Paylaş
great information and pictures, just one thing, what size of fuse should I use for connection in fuse box.
steve finlayson - Yanıt Paylaş
UK road/MOT law states you must 60% dim or better still, make DRL’s turn off when headlights are turned on … stop advertising fake information Phillips and start stating some facts for a change
i cry when i wii - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 100
Her zaman: 96,580
