Ana içeriğe geç
How To Patch A Hole In The Wall
Neye ihtiyacın var
  1. How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: adım 1, 3 resimden 1. How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: adım 1, 3 resimden 2. How To Patch A Hole In The Wall, How To Patch A Hole In The Wall: adım 1, 3 resimden 3.
    • Sand down the hole and the area surrounding. This is in order to get paint off the wall.
  2. How To Patch A Hole In The Wall: adım 2, 2 resimden 1. How To Patch A Hole In The Wall: adım 2, 2 resimden 2.
    • Use the rag and the toothbrush to clean off any excess rubble near the hole.
  3. How To Patch A Hole In The Wall: adım 3, 1 resimden 1.
    • Follow the directions on the spackle box to prepare the spackle for application.
    • Although all spackle brands are different, spackle should have a consistency similar to toothpaste when mixed with water.
  4. How To Patch A Hole In The Wall: adım 4, 3 resimden 1. How To Patch A Hole In The Wall: adım 4, 3 resimden 2. How To Patch A Hole In The Wall: adım 4, 3 resimden 3.
    • Take the spackle mix and apply it to the hole.
    • Make sure to layer the spackle evenly and remove excess spackle.
  5. How To Patch A Hole In The Wall: adım 5, 1 resimden 1.
    • Wait 30-45 minutes for the spackle patch to dry.
    • Wait time may vary depending on the depth of the hole and spackle mix used.
  6. How To Patch A Hole In The Wall: adım 6, 1 resimden 1.
    • Make sure the spackle is dry.
    • Sand the spackle until it is smooth and flush with the wall.
Sonuç
Now your wall should be looking as good as new!
3 farklı kişi bu kılavuzu tamamladı.
Joseph Garcia
293 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-2, Green Fall 2015 Cal Poly, Team 17-2, Green Fall 2015 üyesi
CPSU-GREEN-F15S17G2
4 Üyeler
9 adet Kılavuz yazıldı
1Rehber Yorum
I suggest using a sanding sponge or block in step 6
Dennis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 73
Her zaman: 1,874
