Ana içeriğe geç
How To Patch a Hole in Umbrella Fabric
Neye ihtiyacın var
  1. How To Patch a Hole in Umbrella Fabric, Fabric: adım 1, 1 resimden 1.
    • Remove the fabric from the extender arms of your umbrella.
    • This allows you to more easily work with the torn area, as the fabric won't be held tightly.
  2. How To Patch a Hole in Umbrella Fabric: adım 2, 1 resimden 1.
    • Sew the tear together from the back side of the umbrella using your needle and nylon thread.
    • Be sure to use a thin gauge nylon thread, as cotton threads will soak through and cause leaks in your canopy.
  3. How To Patch a Hole in Umbrella Fabric: adım 3, 1 resimden 1.
    • Cut your patch to an appropriate size relative to the tear.
    • The size of your patch should be big enough to completely cover the tear, with around an inch of additional material on all sides.
  4. How To Patch a Hole in Umbrella Fabric: adım 4, 1 resimden 1.
    • Apply your fabric glue to the backside of your patch material.
  5. How To Patch a Hole in Umbrella Fabric: adım 5, 1 resimden 1.
    • Lay the torn area of the fabric on a flat surface.
  6. How To Patch a Hole in Umbrella Fabric: adım 6, 1 resimden 1.
    • Apply your patch squarely over the torn fabric.
Sonuç
To reassemble your umbrella, reattach the fabric to the rivets that you disconnected it from.
Brandon Hillert
133 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 32
Son 30 gün: 119
Her zaman: 19,532
